system crash Armbian 20.11.4 / 5.9.14-rockchip64
15 hours ago, gprovost said:
Yes new packages with required driver are ready, you can just do the usual apt-get update && apt-get upgrade then reboot.
Sorry for my bad english, I'm French,
I'm using "Armbian_20.11.4_Helios64_buster_current_5.9.14.img.xz"
During the startup sequence I get the following errors:
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xdd6b0
RunBL31 0x40000
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2020.07-armbian (Dec 15 2020 - 08:45:45 +0100)
SoC: Rockchip rk3399
Reset cause: RST
DRAM:  3.9 GiB
PMIC:  RK808
SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
MMC:   mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
How to solve them?
Edited by aprayoga
Move to separate thread
No, that is not an issue.
Please provide complete serial console log.
Is this the first time setup?
Did you upgraded from previous version?
Where did you install the Armbian, eMMC or micro SD card?
