Jaques-Ludwig Posted December 18, 2020 Posted December 18, 2020 Am 5.12.2020 um 04:27 schrieb Zageron: sudo apt-get update && sudo apt-get dist-upgrade -y This will upgrade your unit. I rebooted after doing this, but I'm not sure that you need to. After this, for me nextcloud is no more reachable. I get: Internal Server Error The server encountered an internal error and was unable to complete your request.
Jaques-Ludwig Posted December 18, 2020 Author Posted December 18, 2020 It seems, the apache2 server doesn't start anymore. A restart doesn't work. What can i do? Jaques-Ludwig
Werner Posted December 18, 2020 Posted December 18, 2020 1 hour ago, Jaques-Ludwig said: What can i do? Like on any other platform or system check your logs. Usually /var/log/apache2 or syslog.
Jaques-Ludwig Posted December 18, 2020 Author Posted December 18, 2020 vor 16 Minuten schrieb Werner: Like on any other platform or system check your logs. Usually /var/log/apache2 or syslog. This is on /var/log/apache2/error.log: [Fri Dec 18 16:14:17.465909 2020] [mpm_event:notice] [pid 2269:tid 281473183217008] AH00489: Apache/2.4.38 (Debian) configured -- resuming normal operations [Fri Dec 18 16:14:17.466352 2020] [core:notice] [pid 2269:tid 281473183217008] AH00094: Command line: '/usr/sbin/apache2' [Fri Dec 18 16:41:22.934879 2020] [mpm_event:notice] [pid 2269:tid 281473183217008] AH00491: caught SIGTERM, shutting down [Fri Dec 18 16:41:23.064722 2020] [mpm_event:notice] [pid 12979:tid 281473441314160] AH00489: Apache/2.4.38 (Debian) configured -- resuming normal operations [Fri Dec 18 16:41:23.065120 2020] [core:notice] [pid 12979:tid 281473441314160] AH00094: Command line: '/usr/sbin/apache2' [Fri Dec 18 16:41:41.428506 2020] [mpm_event:notice] [pid 12979:tid 281473441314160] AH00491: caught SIGTERM, shutting down [Fri Dec 18 16:42:57.217141 2020] [mpm_event:notice] [pid 2276:tid 281473446901104] AH00489: Apache/2.4.38 (Debian) configured -- resuming normal operations [Fri Dec 18 16:42:57.217779 2020] [core:notice] [pid 2276:tid 281473446901104] AH00094: Command line: '/usr/sbin/apache2' [Fri Dec 18 16:58:25.293670 2020] [mpm_event:notice] [pid 2276:tid 281473446901104] AH00491: caught SIGTERM, shutting down [Fri Dec 18 16:58:25.405246 2020] [mpm_event:notice] [pid 13167:tid 281473275610480] AH00489: Apache/2.4.38 (Debian) configured -- resuming normal operations [Fri Dec 18 16:58:25.405750 2020] [core:notice] [pid 13167:tid 281473275610480] AH00094: Command line: '/usr/sbin/apache2' [Fri Dec 18 16:58:45.706099 2020] [mpm_event:notice] [pid 13167:tid 281473275610480] AH00491: caught SIGTERM, shutting down [Fri Dec 18 17:00:00.022381 2020] [mpm_event:notice] [pid 2200:tid 281473285526896] AH00489: Apache/2.4.38 (Debian) configured -- resuming normal operations [Fri Dec 18 17:00:00.022823 2020] [core:notice] [pid 2200:tid 281473285526896] AH00094: Command line: '/usr/sbin/apache2' Apache Server works now. But i can't reach nextcloud. I got "internal server error". Where can I look what's the problem? Thanks, Jaques-Ludwig
Werner Posted December 18, 2020 Posted December 18, 2020 I split the topic at this point because its getting offtopic and has most likely nothing more to do with the Helios64. You may want to ask at nextcloud forums/irc/whatever but they probably will tell you the same: check your logs and if there is nothing enable debug modes where available 1
Jaques-Ludwig Posted December 18, 2020 Author Posted December 18, 2020 vor 25 Minuten schrieb Werner: I split the topic at this point because its getting offtopic and has most likely nothing more to do with the Helios64. You may want to ask at nextcloud forums/irc/whatever but they probably will tell you the same: check your logs and if there is nothing enable debug modes where available Ok, thank you.
