GeckoX Posted December 20, 2020 Posted December 20, 2020 Hi, I am opening a new topic to make things clearer. This is a follow-up post from here: After managing to install it, I moved my Helios 4 and switched it on again. It started to work but then it shut down. I cannot switch it on anymore. I don't know if it comes from the Power supply or the motherboard. What are the solutions? Thank you for your help.
aprayoga Posted December 21, 2020 Posted December 21, 2020 You can check the PSU by measuring the output voltage. You can check the motherboard by following instruction on the older support thread. You can also find our recommendation for replacement PSU 1
GeckoX Posted December 21, 2020 Author Posted December 21, 2020 @aprayogaThank you for your answer. It happens that it comes from the PSU. I am glad the board is safe. I ordered a new PSU. and it should work fine.
