hal8k Posted January 6, 2021 Posted January 6, 2021 Armbianmonitor: http://ix.io/2L5X I'm running Armbian Bionic on OPizero. I have a problem using arecord on the mic input. Audio codecs have been enabled but when I run following command to record I get a pcm read error arecord -D plughw:0,0 -d5 -f cd test.wav Recording WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo arecord: pcm_read:2103: read error: Input/output error There is no recording and file is just 44 bytes. pi@orangepizero:~$ ls -l test.wav -rw-r--r-- 1 pi pi 44 Jan 6 20:44 test.wav The output from this command never finishes after 3 seconds and I have to use ctrl+c to breakout: arecord -vvvv -d 3 /dev/null Recording WAVE '/dev/null' : Unsigned 8 bit, Rate 8000 Hz, Mono Plug PCM: Linear conversion PCM (S16_LE) Its setup is: stream : CAPTURE access : RW_INTERLEAVED format : U8 subformat : STD channels : 1 rate : 8000 exact rate : 8000 (8000/1) msbits : 8 buffer_size : 4000 period_size : 1000 period_time : 125000 tstamp_mode : NONE tstamp_type : MONOTONIC period_step : 1 avail_min : 1000 period_event : 0 start_threshold : 1 stop_threshold : 4000 silence_threshold: 0 silence_size : 0 boundary : 2097152000 Slave: Hardware PCM card 0 'H3 Audio Codec' device 0 subdevice 0 Its setup is: stream : CAPTURE access : MMAP_INTERLEAVED format : S16_LE subformat : STD channels : 1 rate : 8000 exact rate : 8000 (8000/1) msbits : 16 buffer_size : 4000 period_size : 1000 period_time : 125000 tstamp_mode : NONE tstamp_type : MONOTONIC period_step : 1 avail_min : 1000 period_event : 0 start_threshold : 1 stop_threshold : 4000 silence_threshold: 0 silence_size : 0 boundary : 2097152000 appl_ptr : 0 hw_ptr : 0 ^CAborted by signal Interrupt... arecord: pcm_read:2103: read error: Interrupted system call The commands work fine on Linux <Mint 19.3 (built on Ubuntu bionic). I first installed Armbian Buster but had same problem, which is why I tried Armbian Bionic After some digging I came up with this bug report: https://bugzilla.redhat.com/show_bug.cgi?id=472469 I'm out of ideas now,. I'm using OPiZero headless, no desktop and login via SSH. ArmbianMonitor logs uploaded at: https://bugzilla.redhat.com/show_bug.cgi?id=472469 Thanks in advance for any help with this.
Igor Posted January 6, 2021 Posted January 6, 2021 1 minute ago, hal8k said: The commands work fine on Linux <Mint 19.3 (built on Ubuntu bionic) I also use Linux Mint for my desktop, but on ARM SBC it is totally useless. Like most of other distros. 2 minutes ago, hal8k said: I first installed Armbian Buster but had same problem,which is why I tried Armbian Bionic The cheap component (common scripts and apps) obviously doesn't matter. https://docs.armbian.com/#what-is-armbian Sadly for the expensive part I don't have any direct answers how to fix since that require research. Don't know, never used audio input on modern kernel, but i think it should be supported. Which means its probably just a device / tree hw misconfiguration or ... Features that aren't wired on boards (board doesn't have audio in) are disabled by default. Now start searching on armbian - you will find answer here or within kernel source tree ... read error: Input/output error is way too generic error that you can catch up on to.
hal8k Posted January 8, 2021 Author Posted January 8, 2021 Hi Igor, Thanks I solved it. Turns out the pcm.read error occurs when you try to record (read) from an input that is disabled in alsamixer. I cant find the post I followed, but solution was alsamixer F4 for capture and then space var on Microphone to enable input. For some reason I am limited to one post/day sorry for delay. Will try and append solved to title
Igor Posted January 8, 2021 Posted January 8, 2021 1 hour ago, hal8k said: Thanks I solved it. Turns out the pcm.read error occurs when you try to record (read) from an input that is disabled in alsamixer. So something even more generic than I thought. Thanks for clarifying. 1 hour ago, hal8k said: For some reason I am limited to one post/day sorry for delay. Will try and append solved to title All new users are limited for up to one week. One is for limiting spam - robots are getting better and better and second that newcomers doesn't start to ask too many (repeated and personal) questions at once without doing a forum search and RTFM. Active creative community has to be protected from those "customers" (over)demands. This hopefully prevents forum downgrade into free technical support service ... with some collateral damages. Anyway, you are no longer limited.
