SPI flash boot doesn't work
Go to solution Solved by jsorocil,
On 12/23/2020 at 12:54 PM, Panzerknacker said:
Boot from SPI directly to NVME works:
Latest U-Boot v2021.01-rc4 + this patch:
rockchip: roc-pc-rk3399: fix boot from SPI flash on spi1
https://patchwork.kernel.org/project/linux-rockchip/list/?series=403611
To build uboot on roc-pc:
make roc-pc-mezzanine-rk3399_defconfig
make -j6
./tools/mkimage -n rk3399 -T rkspi -d tpl/u-boot-tpl.bin:spl/u-boot-spl.bin idbloader-spi.img
To deploy uboot on spi:
dd if=idbloader-spi.img of=spi.img
                  (#0x60000 = 393216 = 4096 * 96)
dd if=u-boot.itb of=spi.img bs=4096 seek=96
flashcp -v spi.img /dev/mtd0
According to this, to run u-boot from flash I just need latest u-boot, apply patch from the link (CONFIG_SF_DEFAULT_BUS=1), copy config to .config, build it, flash it to SPI and it should work?
I did that and for my SOM-RK3399v2 (I have added SPI flash 16 MB chip to it), it starts to boot and it got stuck on line:
Trying to boot from SPI
I am trying for weeks, tried various .configs/OFFSets/various config options/printf debugging/... , various binary files (for RockPro64, PineBook Pro, Roc-PC, etc) and same error. U-boot flashed to SD/eMMC works. SPI flash works in Linux:
mtdinfo /dev/mtd0
mtd0
Type:                           nor
Eraseblock size:                4096 bytes, 4.0 KiB
Amount of eraseblocks:          4096 (16777216 bytes, 16.0 MiB)
Minimum input/output unit size: 1 byte
Sub-page size:                  1 byte
Character device major/minor:   90:0
Bad blocks are allowed:         false
Device is writable:             true
  • Solution
Finally found the problem - HW "issue". My SPI flash is not soldered (no place on motherboard) - it is connected with wires which are (presumably) too long. Workaround is to reduce SPI speed in u-boot and Linux.
U-boot:
diff --git a/arch/arm/dts/rk3399-rockpro64.dtsi b/arch/arm/dts/rk3399-rockpro64.dtsi
index 9bca258012..797dd80d38 100644
--- a/arch/arm/dts/rk3399-rockpro64.dtsi
+++ b/arch/arm/dts/rk3399-rockpro64.dtsi
@@ -677,7 +677,7 @@
        flash@0 {
                compatible = "jedec,spi-nor";
                reg = <0>;
-               spi-max-frequency = <10000000>;
+               spi-max-frequency = <1000000>;
Linux:
Recompile your device tree with reduced SPI speed:
        flash@0 {
                reg = <0>;
