Renan Posted January 14, 2021 Posted January 14, 2021 Hi, I have created an image with the following command /root/build/compile.sh BOARD=orangepi-r1 BRANCH=current RELEASE=focal BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,img ROOTFS_TYPE=ext4 EXTRAWIFI=no CARD_DEVICE=/dev/sdb And it worked fine. Then I changed the filesystem to BTRFS and did /root/build/compile.sh BOARD=orangepi-r1 BRANCH=current RELEASE=focal BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,img ROOTFS_TYPE=btrfs EXTRAWIFI=no CARD_DEVICE=/dev/sdb and got the following errors: sed: couldn't write 19 items to /etc/sed5LHzVg: No space left on device groupadd: /etc/group.2144: No space left on device touch: cannot touch '/home/renan/.Xauthority': No such file or directory Am I missing any extra configuration for BTRFS?
Igor Posted January 14, 2021 Posted January 14, 2021 On 1/14/2021 at 8:26 PM, Renan said: Am I missing any extra configuration for BTRFS? Expand Have you made all round internet research if there is perhaps some bug in BTRFS with kernel 5.10.y? Try at least some BTRFS image with older kernel (change BRANCH=current to BRANCH=legacy) to narrow the problem down. On 1/14/2021 at 8:26 PM, Renan said: and got the following errors: Expand This tells very little. There is output/debug folder for some more data ... did you use recommended host setup? Did you study https://docs.armbian.com/Developer-Guide_Build-Preparation/
Renan Posted January 16, 2021 Author Posted January 16, 2021 Hi, I suspected the error I was getting, No space left on the device, had to do with the root file system. A quick check with df -H: root@orangepi-r1:~# df -H Filesystem Size Used Avail Use% Mounted on udev 92M 0 92M 0% /dev tmpfs 25M 1.7M 24M 7% /run /dev/mmcblk0p2 336M 292M 0 100% / tmpfs 125M 0 125M 0% /dev/shm tmpfs 5.3M 0 5.3M 0% /run/lock tmpfs 125M 0 125M 0% /sys/fs/cgroup tmpfs 125M 4.1k 125M 1% /tmp /dev/mmcblk0p1 244M 39M 194M 17% /boot /dev/zram1 51M 771k 47M 2% /var/log tmpfs 25M 0 25M 0% /run/user/0 Then, I proceeded with a new build with /root/build/compile.sh BOARD=orangepi-r1 BRANCH=current RELEASE=focal BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,img ROOTFS_TYPE=btrfs EXTRAWIFI=no CARD_DEVICE=/dev/sdb FIXED_IMAGE_SIZE=15000 and df -H root@orangepi-r1:~# df -H Filesystem Size Used Avail Use% Mounted on udev 92M 0 92M 0% /dev tmpfs 25M 1.7M 24M 7% /run /dev/mmcblk0p2 16G 240M 15G 2% / tmpfs 125M 0 125M 0% /dev/shm tmpfs 5.3M 0 5.3M 0% /run/lock tmpfs 125M 0 125M 0% /sys/fs/cgroup tmpfs 125M 4.1k 125M 1% /tmp /dev/mmcblk0p1 244M 39M 194M 17% /boot /dev/zram1 51M 791k 47M 2% /var/log tmpfs 25M 0 25M 0% /run/user/0 This time it worked perfectly. My take is that rootfs is not being resized during the first boot when building an image with BTFRS filesystem.
Igor Posted January 16, 2021 Posted January 16, 2021 On 1/16/2021 at 11:55 AM, Renan said: My take is that rootfs is not being resized during the first boot when building an image with BTFRS filesystem. Expand Could be broken ... don't know. Check here: https://github.com/armbian/build/blob/master/packages/bsp/common/usr/lib/armbian/armbian-resize-filesystem Probably initial image size need to be set higher since resize can fail if image is filled up to 100%. https://github.com/armbian/build/blob/master/lib/debootstrap.sh#L399-L406 unless you were adding some packages on top?
Renan Posted January 17, 2021 Author Posted January 17, 2021 After checking, /var/log/armbian-hardware-monitor.log I detected btrfs did not exist in my build. I went back to lib/configuration.sh and saw btrfs-progs package was not installed if BUILD_MINIMAL = YES. if [[ "$BUILD_MINIMAL" != "yes" ]]; then # Essential packages PACKAGE_LIST="$PACKAGE_LIST bridge-utils build-essential fbset \ iw wpasupplicant sudo linux-base crda \ wireless-regdb unattended-upgrades \ console-setup unicode-data initramfs-tools \ ca-certificates expect iptables automake html2text \ bison flex libwrap0-dev libssl-dev libnl-3-dev libnl-genl-3-dev keyboard-configuration" # Non-essential packages PACKAGE_LIST_ADDITIONAL="$PACKAGE_LIST_ADDITIONAL alsa-utils btrfs-progs dosfstools iotop stress screen \ ntfs-3g vim pciutils evtest pv libfuse2 libdigest-sha-perl \ libproc-processtable-perl aptitude dnsutils f3 haveged hdparm rfkill vlan bash-completion \ hostapd git ethtool unzip ifenslave libpam-systemd iperf3 \ software-properties-common libnss-myhostname f2fs-tools avahi-autoipd iputils-arping qrencode sunxi-tools" fi I changed then this from PACKAGE_LIST="bc cpufrequtils device-tree-compiler fping fake-hwclock psmisc chrony parted dialog \ ncurses-term sysfsutils toilet figlet u-boot-tools usbutils openssh-server \ nocache debconf-utils python3-apt" to PACKAGE_LIST="bc btrfs-progs cpufrequtils device-tree-compiler fping fake-hwclock psmisc chrony parted dialog \ ncurses-term sysfsutils toilet figlet u-boot-tools usbutils openssh-server \ nocache debconf-utils python3-apt" And now it works. I suppose btrfs-progs needs to be added to PACKAGE_LIST (or DEBOOTSTRAP_LIST?) only in the case ROOTFS_TYPE=btrfs and irrespectively of BUILD_MINIMAL. 3
Igor Posted January 17, 2021 Posted January 17, 2021 On 1/17/2021 at 12:21 PM, Renan said: And now it works. I suppose btrfs-progs needs to be added to PACKAGE_LIST (or DEBOOTSTRAP_LIST?) only in the case ROOTFS_TYPE=btrfs and irrespectively of BUILD_MINIMAL. Expand Great find! I didn't notice MINIMAL before ... welcome to send a PR.
