sfs Posted January 20, 2021 Posted January 20, 2021 TV Box Status Information Template Version 1.0 TV Box Name : H96 max x3 CPU: amlogic s905x3 Armbian build file name: Armbian_20.10_Arm-64_focal_current_5.9.0_desktop.img.xz DTB file used: meson-sm1-sei610-ethfix.dtb Kernel Version: 5.9.0 Distribution Installed (focal, buster, etc): focal Working Ethernet (Yes/No): Yes Max Ethernet Speed that works (100/1000): 1000 Does wifi work (Yes/No): Yes Does bluetooth work (Yes/No): Yes Does HDMI audio work (Yes/No): Yes wifi+bt with BCM4335C0.hcd Temperature: <70 C SD boot: No USB boot : Yes 1
SteeMan Posted January 20, 2021 Posted January 20, 2021 2 hours ago, sfs said: DTB file used: meson-sm1-sei610-ethfix.dtb @sfs This is not a valid submission. The dtb you reference is not part of the distribution. So a new user couldn't follow the general installation instructions and get your results. As was mentioned in the instructions, you need to only use files from the distribution. You can add comments about how other settings/dtbs/tweeks improved your installation. Also if you are referencing external code, I would request that you also include or link to source code not the compiled objects (i.e. dts vs. dtb). That way in the future someone may be able to maintain this addon/feature as changes to the underlying kernel/environment require.
sfs Posted January 22, 2021 Author Posted January 22, 2021 20.01.2021 в 17:27, SteeMan сказал: if you are referencing external code, I would request that you also include or link to source code not the compiled objects (i.e. dts vs. dtb). meson-sm1-sei610-ethfix.dtb BCM4335C0.hcd H96 max x3 : eng
uppi Posted September 7, 2021 Posted September 7, 2021 Hello , how did you manage to boot it? Which method did you use? I tried both the tooth pick and the direct update to install from settings method, and both didn't work/
uppi Posted September 7, 2021 Posted September 7, 2021 Also what configuration files you used? Can you tell me all of the steps you did?
sfs Posted September 9, 2021 Author Posted September 9, 2021 07.09.2021 в 15:38, uppi сказал: how did you manage to boot it? Which method did you use? tooth pick 07.09.2021 в 17:00, uppi сказал: what configuration files you used? With SD not managed to boot. In the second USB during the start of the download should be empty. Try another USB Flash
uppi Posted September 16, 2021 Posted September 16, 2021 Thanks. But the newer version of the images don't follow same instructions and u-boot.ext was not working for me. So I started looking for the older image files That worked perfectly for me. I have installed it in eMMC and working great. Currently using it as a headless server for my home network with Adguard and samba server with External HDD. USB 3.0 and Gigabit Ethernet are working great. 1
uppi Posted September 16, 2021 Posted September 16, 2021 On 9/9/2021 at 3:49 PM, sfs said: tooth pick With SD not managed to boot. In the second USB during the start of the download should be empty. Try another USB Flash Btw , can you show me your BOOT disk files , if you have them? I was not able to boot the latest image, also which u-boot file did you use?
sfs Posted September 20, 2021 Author Posted September 20, 2021 kernel with AUFS & UKSM -rwxr-xr-x 1 root root 709 дек 28 2020 aml_autoscript -rwxr-xr-x 1 root root 0 дек 28 2020 aml_autoscript.zip -rwxr-xr-x 1 root root 181 дек 28 2020 boot.ini drwxr-xr-x 5 root root 4096 мар 4 2021 dtb-5.10.9-au -rwxr-xr-x 1 root root 135 дек 28 2020 emmc_autoscript drwxr-xr-x 2 root root 4096 мар 12 2021 extlinux -rw-r--r-- 1 ivanov domain users 1417732 фев 25 2021 initrd-lf10.xz -rwxr-xr-x 1 root root 537 дек 28 2020 s905_autoscript -rwxr-xr-x 1 root root 735459 дек 28 2020 u-boot.ext -rwxr-xr-x 1 root root 609247 дек 28 2020 u-boot-s905 -rwxr-xr-x 1 root root 735459 дек 28 2020 u-boot-s905x2-s922 -rwxr-xr-x 1 root root 650183 дек 28 2020 u-boot-s905x-s912 -rwxrwxrwx 1 ivanov domain users 30661120 мар 14 2021 vmlinuz-5.10.9-au
Olli Posted November 17, 2021 Posted November 17, 2021 On 9/16/2021 at 7:42 AM, uppi said: Thanks. But the newer version of the images don't follow same instructions and u-boot.ext was not working for me. So I started looking for the older image files That worked perfectly for me. I have installed it in eMMC and working great. Currently using it as a headless server for my home network with Adguard and samba server with External HDD. USB 3.0 and Gigabit Ethernet are working great. Same issues that you had, cannot get it to boot, tried USB sticks and SD-cards, configurations.. Do you have links to the files you used, mainly the old image file? I am also going to use my H96 MAX X3 as a headless server.
ravijol1 Posted April 27, 2022 Posted April 27, 2022 Could you please link your u-boot.ext file for download?
SteeMan Posted April 27, 2022 Posted April 27, 2022 On 9/20/2021 at 8:09 AM, sfs said: -rwxr-xr-x 1 root root 735459 дек 28 2020 u-boot.ext -rwxr-xr-x 1 root root 609247 дек 28 2020 u-boot-s905 -rwxr-xr-x 1 root root 735459 дек 28 2020 u-boot-s905x2-s922 @ravijol1 per this information posted above, you can see that (by looking at file sizes) he is using the u-boot-s905x2-s922 boot from the distribution. If you were to follow the instructions in the FAQ item (https://forum.armbian.com/topic/17106-installation-instructions-for-tv-boxes-with-amlogic-cpus) this is the uboot file that should be used for this cpu.
