Lukas S Posted January 20, 2021 Posted January 20, 2021 Armbianmonitor: http://ix.io/2MHP Hey, I am using the Image from the Armbian Download site: Armbian_20.11.6_Bananapim2zero_bullseye_current_5.10.4 and I am trying to get SPI to work, enabled it using armbian-config and through editing the /boot/armbianEnv.txt verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 rootdev=UUID=034edbda-9395-4820-87a1-f3a83bad8a58 rootfstype=ext4 overlays=spi-spidev usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u But after a reboot it does not show in /dev/ (what seems odd, i2c-0 shows in /dev/ even though it is not enabled in the armbianEnv.txt) As far as I understand it, the dts for h3 should be the same for h2+ ? I also found a file called "sun8i-h2-plus-bananapi-m2-zero.dtb" under /boot/dtb after some research I found out that this is a device tree binary (thats also why I cant read it) but I couldn't find any information on how to use it. Or how I could replace the spi-spidev.dtd with this h2 one. I also already tried the focal_current_5.10.4 Image same result. Thanks in advance Lukas
Solution martinayotte Posted January 20, 2021 Solution Posted January 20, 2021 1 hour ago, Lukas S said: Thanks in advance You've forgot to define "param_spidev_spi_bus" which is mandatory ...
Lukas S Posted January 20, 2021 Author Posted January 20, 2021 vor 8 Minuten schrieb martinayotte: You've forgot to define "param_spidev_spi_bus" which is mandatory ... Thank you very much, should the armbian-config have set this option ? Sorry I didn't find it in overlay documentation that this flag is needed ^^
martinayotte Posted January 21, 2021 Posted January 21, 2021 20 hours ago, Lukas S said: Sorry I didn't find it in overlay documentation that this flag is needed ^^ Look at this doc file : /boot/dtb/overlay/README.sun8i-h3-overlays
