I have been studying Armbian's build script, and I have managed to extrapolate a standalone u-boot build process for my NanoPC-T4 by cherry-picking the relevant commands / patches from the builder repo:
https://github.com/tmountain/u-boot-nanopct4
This works well, and it opens the door for additional flexibility for those who need it regarding making the most of their hardware. That said, it raises a few questions.
1) My NanoPC-T4 will not boot without the Armbian patches. The vanilla u-boot does not work out of the box. I reported this issue here, but I'm wondering if the Armbian folks ever try to get patches back into upstream?
2) After many attempts, I cannot get a working u-boot (even with the patches) if I try to go the route of linking bl31.elf using the $BL31 environment variable. The only way I can get the loader to work is by building a separate trust.bin using the trust_merger binary. In looking at the Armbian build script, I see that a custom ini file is included with this section related to the BL31:
[BL31_OPTION]
SEC=1
PATH=bl31.elf
ADDR=0x10000
I'm wondering if that ADDR line is the reason that building a trust.bin works, but trying to link against bl31.elf does not. Is there a way to build u-boot without using trust.bin to achieve an identical result? My exact build steps are as follows:
$ docker run -ti ubuntu:focal
# apt-get update
# apt-get -y install build-essential flex bison gcc-aarch64-linux-gnu git \
  device-tree-compiler python3 gcc-arm-none-eabi bc
# cd /root
# git clone https://github.com/tmountain/u-boot-nanopct4
# cd u-boot-nanopct4
# make CROSS_COMPILE=aarch64-linux-gnu- nanopc-t4-rk3399_defconfig
# make u-boot-dtb.bin CROSS_COMPILE=aarch64-linux-gnu-
# tools/mkimage -n rk3399 -T rksd -d vendor/rkbin/blobs/rk3399_ddr_800MHz_v1.24.bin idbloader.bin
# cat vendor/rkbin/blobs/rk3399_miniloader_v1.19.bin >> idbloader.bin
# export PATH=$PATH:`pwd`/vendor/rkbin/bin
# trust_merger --replace bl31.elf vendor/rkbin/blobs/rk3399_bl31_v1.30.elf trust.ini
# loaderimage --pack --uboot ./u-boot-dtb.bin uboot.img
# dd if=idbloader.bin of=/dev/mmcblk2 seek=64 conv=notrunc
# dd if=uboot.img of=/dev/mmcblk2 seek=16384 conv=notrunc
# dd if=trust.bin of=/dev/mmcblk2 seek=24576 conv=notrunc
# sync
Lastly, I want to give a quick thanks to the Armbian project for doing such amazing work. Looking through all of the builder code has really given me an appreciation as to the level of detail and knowledge embedded in this work, and it's super impressive how well everything works out of the box. Thanks!
it's defined by Rockchip, so don't ask why, just follow.
I think can't build without BL31, but you can skip BL32.
Negative. It behaves in the same way as the issue I reported to the u-boot mailing list. You can see my post here:
https://lists.denx.de/pipermail/u-boot/2021-January/437950.html
And my boot log here (via UART):
https://gist.github.com/tmountain/f3fd939dece80aaeb069c28db7d54e3d
The only way I've been able to get the NanoPC-T4 to work is via building a standalone trust.bin and using the Armbian patches.
Your log is only about kernel log. I wonder if your problem is a kernel build configuration. Any means to drop in my kernel also? Make sure you use the same kernel cmd line parameters as the defaut stanza as in the extlinux.conf. Of course, you need to adjust the PARTUUID.
Sure, I will test this. The whole set up right now is a "throwaway".  I'm basically using the nano to learn more about SoC, u-boot, aarch64, etc. I've been testing with the kernel that ships with Nix, but I've also done some testing with kernel that ships with Armbian. I'll report back.
I could not get the aforementioned kernel to work, but I have managed to build a u-boot that works with the NanoPC-T4 without using trust_merger (only using the ATF).
# apt-get update
# apt-get -y install build-essential flex bison gcc-aarch64-linux-gnu git device-tree-compiler python3 gcc-arm-none-eabi bc
# cd /root
# git clone https://github.com/ARM-software/arm-trusted-firmware.git
# git clone https://github.com/u-boot/u-boot.git
# cd arm-trusted-firmware/
# make realclean
# make CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3399 bl31
# cp /root/arm-trusted-firmware/build/rk3399/release/bl31/bl31.elf ../u-boot/
# cd ../u-boot
# git clone http://github.com/armbian/rkbin rkbin
# rkbin=./rkbin
# ./tools/mkimage -n rk3399 -T rksd -d ${rkbin}/rk33/rk3399_ddr_800MHz_v1.24.bin idbloader.img
# cat ${rkbin}/rk33/rk3399_miniloader_v1.19.bin >> idbloader.img
Copy files to target machine...
# dd if=idbloader.img of=/dev/mmcblk2 conv=fsync,notrunc bs=512 seek=64
# dd if=u-boot.itb of=/dev/mmcblk2 conv=fsync,notrunc bs=512 seek=16384
Sorry, but as this is working for me with Fedora userspace, I can't help any further.
But at least you found a solution for a working u-boot.
Yes, my. issue is resolved. Thank you for your help.
