Shubhanshu Posted January 29, 2021 Posted January 29, 2021 I am using Pine A64 1Gb as a development board where I am using Armbian 20.11.7 Buster with Linux 5.10.4-sunxi64 as my OS and i tried installing Numpy either directly on board through terminal or from SSH after running for few minutes it freezes and i have to power reset the board. I am using command: pip3 install --verbose numpy and it freezes after these last few lines: aarch64-linux-gnu-gcc: numpy/core/src/umath/ufunc_object.c aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.7/numpy/core/src/npymath/ieee754.c aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.7/numpy/core/src/npymath/npy_math_complex.c aarch64-linux-gnu-gcc: numpy/core/src/npymath/halffloat.c aarch64-linux-gnu-gcc: numpy/core/src/common/array_assign.c aarch64-linux-gnu-gcc: numpy/core/src/common/mem_overlap.c aarch64-linux-gnu-gcc: numpy/core/src/common/npy_longdouble.c aarch64-linux-gnu-gcc: numpy/core/src/umath/extobj.c aarch64-linux-gnu-gcc: numpy/core/src/common/ucsnarrow.c aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.7/numpy/core/src/umath/scalarmath.c aarch64-linux-gnu-gcc: numpy/core/src/common/ufunc_override.c aarch64-linux-gnu-gcc: numpy/core/src/common/numpyos.c Any help would be great.
Solution tparys Posted January 31, 2021 Solution Posted January 31, 2021 Can you use a pre-packaged copy from the Debian/Ubuntu repositories? # Python 2.x sudo apt install python-numpy # Python 3.x sudo apt install python3-numpy
Werner Posted January 31, 2021 Posted January 31, 2021 Moved to Common issues / peer to peer technical support
Werner Posted January 31, 2021 Posted January 31, 2021 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
Shubhanshu Posted February 2, 2021 Author Posted February 2, 2021 On 2/1/2021 at 12:18 AM, tparys said: Can you use a pre-packaged copy from the Debian/Ubuntu repositories? # Python 2.x sudo apt install python-numpy # Python 3.x sudo apt install python3-numpy Using Python3.x command worked for me. Thanks for help.
