Konstantinusz Posted February 9, 2021 Posted February 9, 2021 (edited) I am planning to buy this device, and I would like to know if I can install Armbian on this device: https://www.amazon.de/-/en/Android-Resolution-Cortex-A53-Support-2-4GHz/dp/B088NDFK4J Edited February 9, 2021 by Konstantinusz
SteeMan Posted February 9, 2021 Posted February 9, 2021 @Konstantinusz Moved your post to the appropriate forum. You have an android TV box, not a supported SBC. Please read the following TV Box FAQ post: https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first
SteeMan Posted February 10, 2021 Posted February 10, 2021 On the TV box side the only H6 based TV Box I am aware of that has any testing is the Tanix TX6 box. See the first post of this thread for instructions on installing: https://forum.armbian.com/topic/12162-single-armbian-image-for-rk-aml-aw-aarch64-armv8 I have no idea if this will work for your H6 based box, but you could try and report back if it worked for you.
MBB Posted March 5, 2021 Posted March 5, 2021 I have tested the TX6, T95 Mini, T95 Max, Q+. All these work well as a small server (w/o WiFi). Of these, I like the T95 Mini the best due to small size and good thermal w/o any modification. Copy to EMMC works. 1
Rashid Posted May 21, 2021 Posted May 21, 2021 @MBB Can you please tell me which DTB works for the T95 mini in the all-in-one image, and the kernel parameters required? It does not boot on the Tanix TX6 DTB. Using the Debian Buster image. I saw your recommendation and I have been trying to get one of these units going with Debian OS. Thank you in advance.
