apocrypha Posted February 12, 2021 Posted February 12, 2021 (edited) Is helios4 usb gadget Ethernet enabled? If it is available, how can it be activated? If the usb gadget Ethernet is not default build , which helios4 kernel build options should I modify? Edited February 12, 2021 by apocrypha 1
aprayoga Posted February 15, 2021 Posted February 15, 2021 @apocrypha, theoretically Helios4 could support USB gadget since the SoC support USB OTG at one of the USB controller, i forgot which one, upper or lower. Unfortunately, Helios4 does not have circuitry to support this operation. Both of the USB is USB Host only. If you're referring to the micro usb port, it is not part of the USB controller of the armada 388. it using external USB to Serial converter IC
