Piscenois Posted February 13, 2021 Posted February 13, 2021 Hi ! I spent several hours looking for the solution, here and elsewhere, I didn't find. The Radxa wiki speaks about 2 SPI: 1 and 2 The device tree README speaks about 4 SPI: SPI 0 pins (MOSI, MISO, SCK, CS): GPIO3_A5, GPIO3_A4, GPIO3_A6, GPIO3_A7 SPI 1 pins (MOSI, MISO, SCK, CS): GPIO1_A7, GPIO1_B0, GPIO1_B1, GPIO1_B2 SPI 2 pins (MOSI, MISO, SCK, CS): GPIO1_C0, GPIO1_B7, GPIO1_C1, GPIO1_C2 SPI 3 pins (MOSI, MISO, SCK, CS): GPIO2_B2, GPIO2_B1, GPIO2_B3, GPIO2_B4 So, the correspondence seems to be: radxa SPI 1 <=> DT SPI 1 radxa SPI2 <=> DT SPI 3 With the latest kernel (5.10.12-rockchip64, Debian buster I tried these configurations: overlays=spi-dev param_spidev_spi_bus=3 and overlays=spi-dev spi-add-cs1 param_spidev_spi_bus=1 param_spidev_spi_cs=1 The first doesn't boot and the second gives the error: [ 2.500481] rockchip-spi ff1d0000.spi: cs1 >= max 1 [ 2.500499] spi_master spi1: spi_device register error /spi@ff1d0000/spidev [ 2.500516] spi_master spi1: Failed to create SPI device for /spi@ff1d0000/spidev I didn't tried the SPI1 because I boot on NVME (SPI1 flash). But this is not mandatory. I could use an SD card or eMMC to boot if it is necessary. Please, how can I achieve the desired configuration: activate GPIO SPI ? Regards
Werner Posted February 13, 2021 Posted February 13, 2021 Your issue report is invalid for one or multiple reasons (non-exhaustive enumeration): it has been stated at the wrong place it lacks fundamental requested data it could have been easily solved by a quick search and/or reading documentation Since you refused to use the bug reporting form carefully and follow the information there as you have been asked for we have no intention to further investigate. https://www.armbian.com/bugs
