[Invalid] - Wireless interface only reachable when ethernet cable plugged orange pi zero
Armbianmonitor:
Hello,  I have problem that wireless interface only reachable when ethernet cable plugged to my orange pi zero.
I use nmtui, to setup my WiFi connection.  All connects fine and works. But when I disconnect ethernet cable, I lost also WiFi connection.
I see this post: https://forum.armbian.com/topic/4098-orange-pi-zero-wifi-issues-when-disconnect-ethernet-cable/
But even after rebooting without ethernet cable, WiFi connnection doesn't work.
Then in a new clean image, I try to run nmtui without connecting ethernet cable. WiFi connects without any errors, but doesn't work.
Please, help!
 This is my ifconfig -a, when ethernet cable connected:
eth0      Link encap:Ethernet  HWaddr 76:77:5e:bc:0b:a9
          inet addr:192.168.1.66  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::7477:5eff:febc:ba9/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:6384 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4665 errors:1 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:457870 (447.1 KiB)  TX bytes:2845538 (2.7 MiB)
          Interrupt:114
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:8 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:480 (480.0 B)  TX bytes:480 (480.0 B)
wlan3     Link encap:Ethernet  HWaddr dc:44:6d:c9:21:66
          inet addr:192.168.1.39  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::de44:6dff:fec9:2166/64 Scope:Link
          RX packets:3 errors:0 dropped:0 overruns:0 frame:0
          TX packets:9 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:624 (624.0 B)  TX bytes:1214 (1.1 KiB)
ifconfig -a without connecting eth cable you can see on photo
Your issue report is invalid for one or multiple reasons (non-exhaustive enumeration):
  • it has been stated at the wrong place
  • it lacks fundamental requested data
  • it could have been easily solved by a quick search and/or reading documentation
Since you refused to use the bug reporting form carefully and follow the information there as you have been asked for we have no intention to further investigate.
https://www.armbian.com/bugs
