Joe Foster Posted February 18, 2021 Posted February 18, 2021 Anyone else ever get just a blank screen? I’m trying to install onto a Trongle S3 box. I’ve tried a number of dtb’s but as it’s a relatively rear box nothing is definite. Tried to match them by spec but hoped it would at least register an output on my monitor. I get a no signal notification. I will be trying to tty the com port but this includes soldering so wanted to see if anyone else knew of a possible solution before I spent time doing this. 1
SteeMan Posted February 18, 2021 Posted February 18, 2021 Moved post to the correct forum. If you want help, please provide information on what exactly you have tried, what build you are working with, what dtb's you have tried, what installation steps you are following, etc. Also please read the following post to set proper expectations: https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first
Joe Foster Posted February 19, 2021 Author Posted February 19, 2021 ***APOLOGIES FOR DELAY, LIMIT ON HOW MANY TIMES I CAN POST PER 24 HOURS*** I've managed to connect via TTL EEPROM connection and am getting the below. I'm using the meson-gxl-s905x-p212.dtb dtb file. With the "Armbian_20.02.0-rc1.037_Aml-s9xxx_bionic_current_5.5.0-rc6_desktop_20200205.img" image. Is "fdt_instaboot: no instaboot image" causing the issue? Any advice is much appreciated. Courtesy note: any one else using this the ttl speed is 115200. Quote =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.02.19 22:27:47 =~=~=~=~=~=~=~=~=~=~=~= GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0; TE: 150401 BL2 Built : 13:48:56, Sep 23 2016. gxl g7459bd4 - jianxin.pan@droid06 set vcck to 1120 mv set vddee to 1000 mv Board ID = 1 CPU clk: 1200MHz DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0+1 @ 912MHz - PASS Rank0: 1024MB(auto)-2T-13 Rank1: 1024MB(auto)-2T-13 DataBus test pass! AddrBus test pass! -s Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x0000d600 Load bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00015400 Load bl33 from eMMC, src: 0x00038200, des: 0x01000000, size: 0x000a9a00 NOTICE: BL3-1: v1.0(debug):2e39a99 NOTICE: BL3-1: Built : 16:36:21, Sep 20 2016 aml log : bl31 normal boot ! [Image: gxl_v1.1.3154-065f772 2016-09-29 14:08:54 yan.wang@droid05] OPS=0x82 e0 64 25 87 a7 56 28 f 21 20 68 3f [0.390607 Inits done] secure task start! high task start! low task start! INFO: BL3-1: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader ERROR: Error initializing runtime service opteed_fast INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01-gdd4a4de (Mar 03 2017 - 18:35:08) DRAM: 2 GiB Relocation Offset is: 76ec9000 register usb cfg[0][1] = 0000000077f5f500 vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters vpu: clk_level = 7 vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300) vpp: vpp_init boot_device_flag : 1 Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc. init bus_cycle=6, bus_timing=7, system=5.0ns reset failed get_chip_type and ret:fffffffe get_chip_type and ret:fffffffe chip detect failed and ret:fffffffe nandphy_init failed and ret=0xfffffff1 MMC: aml_priv->desc_buf = 0x0000000073ec96b0 aml_priv->desc_buf = 0x0000000073ecb9d0 SDIO Port B: 0, SDIO Port C: 1 emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 [mmc_init] mmc init success mmc read lba=0x14000, blocks=0x400 Amlogic multi-dtb tool Multi dtb detected Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxl platform: p212 variant: 2g dtb 0 soc: gxl plat: p212 vari: 1g dtb 1 soc: gxl plat: p212 vari: 2g Find match dtb: 1 start dts,buffer=0000000073ece270,dt_addr=0000000073ed8270 parts: 11 00: logo 0000000002000000 1 01: recovery 0000000002000000 1 02: rsv 0000000000800000 1 03: tee 0000000000800000 1 04: crypt 0000000002000000 1 05: misc 0000000002000000 1 06: instaboot 0000000020000000 1 07: boot 0000000002000000 1 08: system 0000000080000000 1 09: cache 0000000020000000 2 10: data ffffffffffffffff 4 get_dtb_struct: Get emmc dtb OK! overide_emmc_partition_table: overide cache [mmc_get_partition_table] skip partition cache. Partition table get from SPL is : name offset size flag =================================================================================== 0: bootloader 0 400000 0 1: reserved 2400000 4000000 0 2: cache 6c00000 20000000 2 3: env 27400000 800000 0 4: logo 28400000 2000000 1 5: recovery 2ac00000 2000000 1 6: rsv 2d400000 800000 1 7: tee 2e400000 800000 1 8: crypt 2f400000 2000000 1 9: misc 31c00000 2000000 1 10: instaboot 34400000 20000000 1 11: boot 54c00000 2000000 1 12: system 57400000 80000000 1 13: data d7c00000 2c5400000 4 mmc read lba=0x12000, blocks=0x2 mmc read lba=0x12002, blocks=0x2 mmc_read_partition_tbl: mmc read partition OK! eMMC/TSD partition table have been checked OK! mmc env offset: 0x27400000 In: serial Out: serial Err: serial reboot_mode=cold_boot hpd_state=0 cvbs performance type = 6, table = 0 [store]To run cmd[emmc dtb_read 0x1000000 0x40000] read emmc dtb Amlogic multi-dtb tool Multi dtb detected Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxl platform: p212 variant: 2g dtb 0 soc: gxl plat: p212 vari: 1g dtb 1 soc: gxl plat: p212 vari: 2g Find match dtb: 1 Net: dwmac.c9410000 wipe_data=successful wipe_cache=successful upgrade_step=2 [OSD]load fb addr from dts [OSD]failed to get fb addr for logo [OSD]use default fb_addr parameters [OSD]fb_addr for logo: 0x3d800000 [OSD]load fb addr from dts [OSD]failed to get fb addr for logo [OSD]use default fb_addr parameters [OSD]fb_addr for logo: 0x3d800000 [CANVAS]canvas init [CANVAS]addr=0x3d800000 width=5760, height=2160 amlkey_init() enter! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 [KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet [KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet get_cpu_id flag_12bit=1 SARADC open channel(0). SARADC channel(0) is 0x3ef, Out of range(0x0~0x50)! saradc - saradc sub-system Usage: saradc saradc open <channel> - open a SARADC channel saradc close - close the SARADC saradc getval - get the value in current channel saradc get_in_range <min> <max> - return 0 if current value in the range of current channel InUsbBurn noSof Hit Enter or space or Ctrl+C key to stop autoboot -- : 1 0 card in [mmc_init] mmc init success Device: SDIO Port B Manufacturer ID: 3 OEM: 3456 Name: ASTCTran Speed: 50000000 Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 29.5 GiB mmc clock: 40000000 Bus Width: 4-bit reading s905_autoscript 1351 bytes read in 5 ms (263.7 KiB/s) ## Executing script at 01020000 start amlogic old u-boot reading boot_android ** Unable to read file boot_android ** ** Bad device usb 0 ** reading u-boot.ext ** Unable to read file u-boot.ext ** ** Bad device usb 0 ** reading uEnv.txt 1157 bytes read in 4 ms (282.2 KiB/s) mac=42:f2:9e:a9:91:c3 reading /zImage 23357952 bytes read in 1295 ms (17.2 MiB/s) reading /uInitrd 11037395 bytes read in 615 ms (17.1 MiB/s) reading /dtb/amlogic/meson-g12b-odroid-n2.dtb 47774 bytes read in 9 ms (5.1 MiB/s) libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND [rsvmem] bl31 reserved memory set addr error. ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 11037331 Bytes = 10.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Amlogic multi-dtb tool Single dtb detected load dtb from 0x1000000 ...... ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000 libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND [rsvmem] bl31 reserved memory set addr error. Loading Ramdisk to 7342f000, end 73eb5a93 ... OK Loading Device Tree to 000000001fff1000, end 000000001ffffa9d ... OK signature: fdt_instaboot: no instaboot image Starting kernel ... uboot time: 4530887 us Expand
SteeMan Posted February 20, 2021 Posted February 20, 2021 Please describe what steps you are performing. The log would indicate you are booting with dtb/amlogic/meson-g12b-odroid-n2.dtb, not the dtb you think you are.
