Armbianmonitor:
I tried Armbian_21.02.1_Orangepi4_bionic_current_5.10.12_minimal.img and Armbian_21.02.1_Orangepi4_buster_current_5.10.12.img
but these two version the eth0 doesn't work. This is the ifconfig printout
Last login: Thu Feb 25 09:07:13 2021
root@orangepi4:~# ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 6e:6d:04:05:d9:8c  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 35
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.68.112  netmask 255.255.255.0  broadcast 192.168.68.255
        inet6 fe80::120d:4bf9:fc2a:4604  prefixlen 64  scopeid 0x20<link>
        ether c0:84:7d:31:4f:92  txqueuelen 1000  (Ethernet)
        RX packets 90  bytes 10915 (10.6 KiB)
        TX packets 100  bytes 18412 (17.9 KiB)
Tried using nmtui to activate but it does not activate and return
        |  |     |   Could not activate connection:  │       │
        │ │   │ Connection 'Wired connection 1' │       │
        │ │   │ is not available on device eth0 │       │
        │ │   │ because device has no carrier
  • thanh_tan changed the title to Orange pi 4 got eth0 interrupt kernel 5.10.12
