How can I move the root filesystem manually from sata drive to eMMC
After I first installed my Helios64, I feared the 16Gb eMMC would be quickly filled.
So when I used nand-sata-install, I chose to boot from eMMC but to have the root filesystem on a 500Gb sata drive.
I have now second thoughts about it, since I realized that the OS take less than 8Gb, AND I'd like to add a 5th disk to my raid :)
Halas nand-sata-install doesn't seem to work on an already moved filsystem.
lsblk show this for the eMMC and the root partition
peyo@helios64:~$ lsblk
NAME         MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINT
sda            8:0    0 465,8G  0 disk
└─sda1         8:1    0 465,8G  0 part  /
mmcblk2      179:0    0  14,6G  0 disk
└─mmcblk2p1  179:1    0  14,4G  0 part  /media/mmcboot
And /etc/fstab shows this
UUID=f2d7d6e7-902c-44dc-bdae-aedeb4495385    /media/mmcboot    ext4    defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide    0    1
/media/mmcboot/boot                   /boot        none    bind                                0       0
UUID=0fcd9a2c-9a46-4a5e-a0f5-e407bd34e8fb    /        ext4    defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide    0    1
And in /media I have this
peyo@helios64:~$ ll /media/
total 8
drwxr-xr-x 3 root root 4096 déc.   6 11:31 mmcboot
drwxr-xr-x 2 root root 4096 déc.   6 11:31 mmcroot
Would it be so simple as
1 - rsync all that's on my present / (except for the NFS export and /tmp)?
2 - changin /etc/fstab to this
UUID=f2d7d6e7-902c-44dc-bdae-aedeb4495385    /    ext4    defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide    0    1
3 - reboot (with crossed fingers)
Thanks for you help
Yes unfortunately nand-sata-install does not work the other way around, I'm looking at it currently since there was another use case related to install on OS rootfs on HDD that wasn't also supported.
The step for you case should be :
1. First boot the system on a microSD card with a fresh install of Armbian.
2. Copy rootfs from old destination (HDD) to new destination (eMMC)
mkdir /mnt/rfs_new /mnt/rfs_old
mount /dev/mmcblk2p1 /mnt/rfs_new/
mount /dev/sdX1 /mnt/rfs_old/
rsync -avrlt --delete --exclude-from=/usr/lib/nand-sata-install/exclude.txt /mnt/rfs_old/ /mnt/rfs_new/
3. use command blkid to know the UUID of /dev/mmcblk2p1
4. Modify /mnt/rfs_new/boot/armbianEnv.txt to modify rootdev line with the UUID of /dev/mmcblk2p1
verbosity=1
bootlogo=false
overlay_prefix=rockchip
rootdev=UUID=075c8660-77ca-4048-a04b-be3364c60a40
rootfstype=ext4
5. Modify /mnt/rfs_new/etc/fstab
- Remove /media/mmcboot and /boot mount point lines
- Edit / mount point to use the UUID of /dev/mmcblk2p1
# <file system>					<mount point>	<type>	<options>							<dump>	<pass>
tmpfs						/tmp		tmpfs	defaults,nosuid							0	0
UUID=075c8660-77ca-4048-a04b-be3364c60a40	/		ext4	defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide	0	1
6. Sync and Poweroff
7. Remove microSD and Poweron (maybe cross your finger also)
Great thanks, I'll try that as soon as possible
Update : Just did it, it worked like a charm, thanks a bunch!
Edited by ploubi
