paagutie Posted March 12, 2021 Share Posted March 12, 2021 Armbianmonitor: https://paste.ubuntu.com/p/QP9CM4csQy/ Hello everyone, due to a project I'm working with the Friendly Elec Nanopi R4S board for which I've to use the i2c bus to read data from a sensor. Unfortunately I've not been able to access it, since the system does not recognize it. I tried with different configurations using the /boot/armbianEnv.txt file with no results, however the i2c ports are enabled. To rule out functionality problems in the sensor, I connected it to other boards (e.g. nanopi Neo3 using Armbian) without problems. Do you have any idea what could be the cause of this problem? Thanks! 0 Quote Link to comment Share on other sites More sharing options...
mef1k Posted October 3, 2022 Share Posted October 3, 2022 Hi, I ran into the same problem, tell me if you managed to find a solution? 0 Quote Link to comment Share on other sites More sharing options...
