Rob Gillan Posted March 13, 2021 Posted March 13, 2021 Hello, bit of a strange one here. Using Armbian 21.02.3 Bionic with Linux 5.10.21-sunxi on a NanoPi Neo Core. Using nmtui to set a static IP on the Ethernet interface and all is good. On reboot, a second interface is added (dhcp) and the static interface disabled. Any help at keeping a static IP that survives a restart would be very much appreciated, Cheers Rob
Werner Posted March 13, 2021 Posted March 13, 2021 Your issue report is invalid for one or multiple reasons (non-exhaustive enumeration): it has been stated at the wrong place it lacks fundamental requested data it could have been easily solved by a quick search and/or reading documentation unsupported userspace/image/SBC Since you refused to use the bug reporting form carefully and follow the information there as you have been asked for we have no intention to further investigate. Please add missing information if applicable. https://www.armbian.com/bugs
