tmb Posted March 18, 2021 Posted March 18, 2021 I’ve googled it but can’t decide, the drive works just fine (it’s the 1st of the three disks I have in the box), no performance issues when copying from/to the box. I’m currently on “Armbian 20.11”, barely get the time to play with the setup due to work assignments, plan to update soon. Thanks! (PS. Newbie here) [ 13.298079] ata1: softreset failed (1st FIS failed) [ 18.449169] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 18.467303] ata1.00: ATA-10: ST6000VN0033-2EE110, SC60, max UDMA/133 [ 18.467315] ata1.00: 11721045168 sectors, multi 0: LBA48 NCQ (depth 32), AA [ 18.470029] ata1.00: configured for UDMA/133 [ 18.470721] scsi 0:0:0:0: Direct-Access ATA ST6000VN0033-2EE SC60 PQ : 0 ANSI: 5 [ 18.472237] sd 0:0:0:0: [sda] 11721045168 512-byte logical blocks: (6.00 TB/5 .46 TiB) [ 18.472247] sd 0:0:0:0: [sda] 4096-byte physical blocks [ 18.472299] sd 0:0:0:0: [sda] Write Protect is off [ 18.472309] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 18.472393] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, does n't support DPO or FUA [ 18.580573] sda: sda1 [ 18.583350] sd 0:0:0:0: [sda] Attached SCSI disk [ 18.949151] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 18.959809] ata2.00: ATA-10: ST6000VN0033-2EE110, SC60, max UDMA/133 [ 18.959822] ata2.00: 11721045168 sectors, multi 0: LBA48 NCQ (depth 32), AA [ 18.962526] ata2.00: configured for UDMA/133 [ 18.963133] scsi 1:0:0:0: Direct-Access ATA ST6000VN0033-2EE SC60 PQ : 0 ANSI: 5 [ 18.964436] sd 1:0:0:0: [sdb] 11721045168 512-byte logical blocks: (6.00 TB/5 .46 TiB) [ 18.964451] sd 1:0:0:0: [sdb] 4096-byte physical blocks [ 18.964520] sd 1:0:0:0: [sdb] Write Protect is off [ 18.964534] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00 [ 18.964651] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, does n't support DPO or FUA [ 19.017200] sdb: sdb1 [ 19.019847] sd 1:0:0:0: [sdb] Attached SCSI disk [ 19.441176] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 19.450989] ata3.00: ATA-10: ST6000VN0033-2EE110, SC60, max UDMA/133 [ 19.451001] ata3.00: 11721045168 sectors, multi 0: LBA48 NCQ (depth 32), AA [ 19.453715] ata3.00: configured for UDMA/133 [ 19.454064] scsi 2:0:0:0: Direct-Access ATA ST6000VN0033-2EE SC60 PQ : 0 ANSI: 5 [ 19.455164] sd 2:0:0:0: [sdc] 11721045168 512-byte logical blocks: (6.00 TB/5 .46 TiB) [ 19.455178] sd 2:0:0:0: [sdc] 4096-byte physical blocks [ 19.455248] sd 2:0:0:0: [sdc] Write Protect is off [ 19.455262] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00 [ 19.455378] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, does n't support DPO or FUA [ 19.507285] sdc: sdc1 [ 19.509063] sd 2:0:0:0: [sdc] Attached SCSI disk [ 19.767590] ata4: SATA link down (SStatus 0 SControl 300) [ 20.079588] ata5: SATA link down (SStatus 0 SControl 300)
