nopnop2002 Posted August 2, 2016 Share Posted August 2, 2016 I use OPI - ONE. I upgraded a package. The CPU temperature become so hot. Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.112-sun8i System load: 0.29 Up time: 7 min Memory usage: 11 % of 494Mb IP: 192.168.10.112 192.168.10.116 CPU temp: 60°C Usage of /: 18% of 7.2G Last login: Tue Aug 2 16:42:15 2016 from 192.168.10.101 orangepi@orangepione:~$ cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepione BOARD_NAME="Orange Pi One" VERSION=5.16 LINUXFAMILY=sun8i BRANCH=default ARCH=arm orangepi@orangepione:~$ cat /sys/devices/virtual/thermal/thermal_zone0/temp 59 orangepi@orangepione:~$ cat /sys/devices/virtual/thermal/thermal_zone1/temp 59 Link to comment Share on other sites More sharing options...
tkaiser Posted August 2, 2016 Share Posted August 2, 2016 Please provide the output from 'sudo armbianmonitor -u' Link to comment Share on other sites More sharing options...
wildcat_paris Posted August 2, 2016 Share Posted August 2, 2016 @Thomas Please provide the output from 'sudo armbianmonitor -u' you may put this sentence as a signature, please it might sound useful Link to comment Share on other sites More sharing options...
nopnop2002 Posted August 2, 2016 Author Share Posted August 2, 2016 Please provide the output from 'sudo armbianmonitor -u' orangepi@orangepione:~$ sudo armbianmonitor -u /var/log/armhwinfo.log has been uploaded to http://sprunge.us/BMGK Please post the URL in the Armbian forum where you've been asked for. Link to comment Share on other sites More sharing options...
tkaiser Posted August 3, 2016 Share Posted August 3, 2016 Hmm... there are no anomalies (except of SD card errors) in the logs. How do a few lines output of 'sudo armbianmonitor -m' look like? Link to comment Share on other sites More sharing options...
RagnerBG Posted August 3, 2016 Share Posted August 3, 2016 I use OPI - ONE. I upgraded a package. The CPU temperature become so hot. Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.112-sun8i System load: 0.29 Up time: 7 min Memory usage: 11 % of 494Mb IP: 192.168.10.112 192.168.10.116 CPU temp: 60°C Usage of /: 18% of 7.2G Last login: Tue Aug 2 16:42:15 2016 from 192.168.10.101 orangepi@orangepione:~$ cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepione BOARD_NAME="Orange Pi One" VERSION=5.16 LINUXFAMILY=sun8i BRANCH=default ARCH=arm orangepi@orangepione:~$ cat /sys/devices/virtual/thermal/thermal_zone0/temp 59 orangepi@orangepione:~$ cat /sys/devices/virtual/thermal/thermal_zone1/temp 59 I think 60°C is completely normal for OPI ONE if there is no heatsink at SoC. Mine, with heatsink was around 45/50°C idle in Armbian and this was in more coldly weather, couple of mounts ago. While in OpenElec i use the most in this board it easily reach near 90°C idle. So this temperature is ok for me, if there is no tweaks about this in recent Armbian. Link to comment Share on other sites More sharing options...
nopnop2002 Posted August 3, 2016 Author Share Posted August 3, 2016 Hmm... there are no anomalies (except of SD card errors) in the logs. How do a few lines output of 'sudo armbianmonitor -m' look like? Thank you for checking it. orangepi@orangepione:~$ sudo armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU 15:31:24: 1008MHz 0.16 0% 0% 0% 0% 0% 0% 55°C 15:31:29: 480MHz 0.23 0% 0% 0% 0% 0% 0% 55°C 15:31:34: 480MHz 0.21 0% 0% 0% 0% 0% 0% 55°C 15:31:39: 480MHz 0.19 1% 0% 0% 0% 0% 0% 55°C 15:31:45: 1008MHz 0.26 3% 1% 1% 0% 0% 0% 57°C 15:31:50: 480MHz 0.24 3% 1% 1% 0% 0% 0% 55°C 15:31:55: 480MHz 0.22 3% 1% 2% 0% 0% 0% 55°C 15:32:00: 480MHz 0.20 3% 1% 2% 0% 0% 0% 55°C 15:32:05: 480MHz 0.18 3% 1% 2% 0% 0% 0% 55°C 15:32:10: 480MHz 0.17 1% 1% 0% 0% 0% 0% 55°C 15:32:15: 480MHz 0.16 1% 0% 0% 0% 0% 0% 55°C 15:32:20: 480MHz 0.14 1% 0% 0% 0% 0% 0% 55°C The record when using Armbian_5.14 was left. orangepi@orangepione:~$ cat /sys/devices/virtual/thermal/thermal_zone0/temp 45 orangepi@orangepione:~$ cat /sys/devices/virtual/thermal/thermal_zone1/temp 46 I'll install this release again and check it. EDIT I tried. I think there is cause in USB-Wifi module. Disable Wifi: orangepi@orangepione:~$ cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepione ID="Orange Pi One" VERSION=5.14 LINUXFAMILY=sun8i BRANCH=default orangepi@orangepione:~$ sudo armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU 16:01:34: 1008MHz 0.06 3% 1% 0% 0% 1% 0% 49°C 16:01:39: 480MHz 0.06 3% 1% 0% 0% 1% 0% 49°C 16:01:44: 480MHz 0.05 3% 1% 0% 0% 1% 0% 49°C 16:01:49: 480MHz 0.05 3% 1% 0% 0% 1% 0% 49°C 16:01:54: 480MHz 0.05 2% 1% 0% 0% 1% 0% 49°C 16:02:00: 480MHz 0.04 2% 1% 0% 0% 1% 0% 49°C 16:02:05: 480MHz 0.04 2% 1% 0% 0% 1% 0% 49°C 16:02:10: 480MHz 0.04 2% 1% 0% 0% 1% 0% 49°C 16:02:15: 480MHz 0.03 2% 0% 0% 0% 1% 0% 49°C 16:02:20: 480MHz 0.03 2% 0% 0% 0% 1% 0% 49°C 16:02:25: 480MHz 0.03 2% 0% 0% 0% 0% 0% 50°C 16:02:30: 480MHz 0.03 2% 0% 0% 0% 0% 0% 49°C 16:02:35: 480MHz 0.02 2% 0% 0% 0% 0% 0% 49°C 16:02:41: 480MHz 0.02 2% 0% 0% 0% 0% 0% 50°C Enable Wifi: orangepi@orangepione:~$ cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepione ID="Orange Pi One" VERSION=5.14 LINUXFAMILY=sun8i BRANCH=default orangepi@orangepione:~$ sudo armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU 16:28:44: 1008MHz 0.10 1% 0% 0% 0% 0% 0% 58°C 16:28:50: 480MHz 0.09 1% 0% 0% 0% 0% 0% 58°C 16:28:55: 480MHz 0.08 1% 0% 0% 0% 0% 0% 58°C 16:29:00: 480MHz 0.08 1% 0% 0% 0% 0% 0% 58°C 16:29:05: 480MHz 0.07 1% 0% 0% 0% 0% 0% 58°C 16:29:10: 480MHz 0.06 1% 0% 0% 0% 0% 0% 58°C 16:29:15: 480MHz 0.06 1% 0% 0% 0% 0% 0% 59°C 16:29:20: 480MHz 0.05 1% 0% 0% 0% 0% 0% 59°C 16:29:25: 480MHz 0.05 1% 0% 0% 0% 0% 0% 59°C 16:29:30: 480MHz 0.05 1% 0% 0% 0% 0% 0% 59°C 16:29:36: 480MHz 0.04 1% 0% 0% 0% 0% 0% 59°C 16:29:41: 480MHz 0.04 1% 0% 0% 0% 0% 0% 59°C orangepi@orangepione:~$ lsusb Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 002: ID 0bda:0179 Realtek Semiconductor Corp. Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub I'll change USB-Wifi dongle. EDIT2 I changed the USB dongle to RTL8188CUS. The situation was improved. orangepi@orangepione:~$ cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepione ID="Orange Pi One" VERSION=5.14 LINUXFAMILY=sun8i BRANCH=default orangepi@orangepione:~$ sudo armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU 00:07:07: 1008MHz 0.01 0% 0% 0% 0% 0% 0% 53°C 00:07:12: 480MHz 0.01 0% 0% 0% 0% 0% 0% 54°C 00:07:17: 480MHz 0.01 0% 0% 0% 0% 0% 0% 53°C 00:07:22: 480MHz 0.01 0% 0% 0% 0% 0% 0% 53°C 00:07:27: 480MHz 0.01 0% 0% 0% 0% 0% 0% 53°C 00:07:32: 480MHz 0.01 0% 0% 0% 0% 0% 0% 53°C 00:07:37: 480MHz 0.00 0% 0% 0% 0% 0% 0% 53°C 00:07:43: 480MHz 0.00 0% 0% 0% 0% 0% 0% 52°C 00:07:48: 480MHz 0.00 0% 0% 0% 0% 0% 0% 53°C 00:07:53: 480MHz 0.00 0% 0% 0% 0% 0% 0% 52°C 00:07:58: 480MHz 0.00 0% 0% 0% 0% 0% 0% 52°C 00:08:03: 480MHz 0.00 0% 0% 0% 0% 0% 0% 52°C EDIT3 I upgraded a package. The CPU temperature becomes high as expected. orangepi@orangepione:~$ cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepione BOARD_NAME="Orange Pi One" VERSION=5.16 LINUXFAMILY=sun8i BRANCH=default ARCH=arm orangepi@orangepione:~$ sudo armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU 10:45:53: 1008MHz 0.11 0% 0% 0% 0% 0% 0% 64°C 10:45:58: 480MHz 0.10 0% 0% 0% 0% 0% 0% 64°C 10:46:03: 480MHz 0.09 0% 0% 0% 0% 0% 0% 64°C 10:46:08: 480MHz 0.09 0% 0% 0% 0% 0% 0% 64°C 10:46:13: 480MHz 0.08 0% 0% 0% 0% 0% 0% 64°C 10:46:19: 480MHz 0.07 0% 0% 0% 0% 0% 0% 64°C 10:46:24: 480MHz 0.07 0% 0% 0% 0% 0% 0% 64°C 10:46:29: 480MHz 0.06 0% 0% 0% 0% 0% 0% 64°C 10:46:34: 480MHz 0.06 0% 0% 0% 0% 0% 0% 64°C Link to comment Share on other sites More sharing options...
nopnop2002 Posted August 6, 2016 Author Share Posted August 6, 2016 I updated Armbian from 5.16 to 5.17. I think this problem was resolved. orangepi@orangepione:~$ cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepione BOARD_NAME="Orange Pi One" VERSION=5.16 LINUXFAMILY=sun8i BRANCH=default ARCH=arm orangepi@orangepione:~$ sudo armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU 10:45:53: 1008MHz 0.11 0% 0% 0% 0% 0% 0% 64°C 10:45:58: 480MHz 0.10 0% 0% 0% 0% 0% 0% 64°C 10:46:03: 480MHz 0.09 0% 0% 0% 0% 0% 0% 64°C 10:46:08: 480MHz 0.09 0% 0% 0% 0% 0% 0% 64°C 10:46:13: 480MHz 0.08 0% 0% 0% 0% 0% 0% 64°C 10:46:19: 480MHz 0.07 0% 0% 0% 0% 0% 0% 64°C 10:46:24: 480MHz 0.07 0% 0% 0% 0% 0% 0% 64°C 10:46:29: 480MHz 0.06 0% 0% 0% 0% 0% 0% 64°C 10:46:34: 480MHz 0.06 0% 0% 0% 0% 0% 0% 64°C orangepi@orangepione:~$ cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepione BOARD_NAME="Orange Pi One" VERSION=5.17 LINUXFAMILY=sun8i BRANCH=default ARCH=arm orangepi@orangepione:~$ sudo armbianmonitor -m [sudo] password for orangepi: Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU 11:24:04: 1152MHz 0.01 0% 0% 0% 0% 0% 0% 51°C 11:24:09: 480MHz 0.01 0% 0% 0% 0% 0% 0% 51°C 11:24:14: 480MHz 0.01 0% 0% 0% 0% 0% 0% 51°C 11:24:19: 480MHz 0.01 0% 0% 0% 0% 0% 0% 50°C 11:24:25: 480MHz 0.01 0% 0% 0% 0% 0% 0% 51°C 11:24:30: 480MHz 0.01 0% 0% 0% 0% 0% 0% 51°C 11:24:35: 480MHz 0.01 0% 0% 0% 0% 0% 0% 51°C 11:24:40: 480MHz 0.09 0% 0% 0% 0% 0% 0% 51°C 11:24:45: 480MHz 0.07 0% 0% 0% 0% 0% 0% 51°C Link to comment Share on other sites More sharing options...
