vmiceli Posted March 23, 2021 Posted March 23, 2021 (edited) Hello folks, I have been banging my head on this for a few days now and after many searches what should work it is not working :-( I'm setting up an NTP server on a NanoPi Neo3 board (RK3328) running Armbian and I'm stuck on getting the PPS to work. I have a GPS connected issuing the PPS signal on pin 16 but I don't seem to be able to make it visible to the NanoPi. Here are the usual reports to show what OS I'm running. "cat /etc/armbian-release" # PLEASE DO NOT EDIT THIS FILE BOARD=nanopineo3 BOARD_NAME="NanoPi Neo 3" BOARDFAMILY=rockchip64 BUILD_REPOSITORY_URL=git@github.com:armbian/build.git BUILD_REPOSITORY_COMMIT=e846ef656-dirty DISTRIBUTION_CODENAME=buster DISTRIBUTION_STATUS=supported VERSION=21.02.3 LINUXFAMILY=rockchip64 BRANCH=current ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf "uname -a" Linux DietPiNTP 5.10.21-rockchip64 #21.02.3 SMP PREEMPT Mon Mar 8 01:05:08 UTC 2021 aarch64 GNU/Linux Some Kernel info regarding PPS using "gzip -d < /proc/config.gz | egrep -i pps" CONFIG_PPS=y # CONFIG_PPS_DEBUG is not set # PPS clients support # CONFIG_PPS_CLIENT_KTIMER is not set CONFIG_PPS_CLIENT_LDISC=m CONFIG_PPS_CLIENT_GPIO=m # PPS generators support What should work to enable PPS on Armbian is to add the bottom two lines below into /boot/armbianEnv.txt verbosity=4 bootlogo=false overlay_prefix=rockchip fdtfile=rockchip/rk3328-nanopi-r2-rev00.dtb rootdev=UUID=7f26bae3-11cc-4a08-bcc6-df7f80c7d91b rootfstype=ext4 console=none usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u docker_optimizations=off overlays=pps-gpio param_pps_pin=101 I have serious doubts on the pin naming convention but from the board manufacturer I picked pin 16 named GPIO3_A5/UART1_RTSN with a Linux pin number of 101. So I just used 101 in the param_pps_pin line. This is however not working, I would expect a line in dmesg after reboot stating that a particular pin has been associated to the kernel pps driver, but nothing of that shows up. Even if the pin name is wrong I should see the error message of that association failing I think. All I get is the standard two lines below: root@DietPiNTP:/boot# dmesg | grep pps [ 1.269816] pps_core: LinuxPPS API ver. 1 registered [ 1.269828] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> Just as reference here are the details of the pps-gpio driver root@DietPiNTP:/boot# modinfo pps_gpio filename: /lib/modules/5.10.21-rockchip64/kernel/drivers/pps/clients/pps-gpio.ko version: 1.2.0 license: GPL description: Use GPIO pin as PPS source author: James Nuss <jamesnuss@nanometrics.ca> author: Ricardo Martins <rasm@fe.up.pt> srcversion: DC2C20835E78E639C78ED8B alias: of:N*T*Cpps-gpioC* alias: of:N*T*Cpps-gpio depends: intree: Y name: pps_gpio vermagic: 5.10.21-rockchip64 SMP preempt mod_unload aarch64 sig_id: PKCS#7 signer: Build time autogenerated kernel key sig_key: 6E:AA:FB:15:C6:2A:4C:E0:0C:E1:53:9F:10:36:C1:FF:68:CC:6E:CC sig_hashalgo: sha1 signature: B8:CB:6F:BC:D7:D0:5B:1D:80:29:46:EF:1E:BC:58:69:8C:61:01:FF: ... I hope you made it to the end of this long post :-) Is there any feedback or comment that can help me get on the right track? Thanks a million!!! Enzo Edited March 23, 2021 by vmiceli Added some more detail
vmiceli Posted March 27, 2021 Author Posted March 27, 2021 I got the PPS kernel driver to load. I did that by recompiling the Kernel applying a patch to rk3328-nanopi-neo3-rev02.dts. The patch adds --- rk3328-nanopi-neo3-rev02.dts 2021-03-27 00:06:41.000000000 +0000 +++ New_rk3328-nanopi-neo3-rev02.dts 2021-03-26 20:53:07.000000000 +0000 @@ -30,6 +30,13 @@ debounce-interval = <100>; }; }; + + pps { + gpios = <&gpio3 RK_PA5 GPIO_ACTIVE_LOW>; + + compatible = "pps-gpio"; + + }; i2s-sound { compatible = "simple-audio-card"; In this way I can assign a specfic GPIO as PPS input. In this case is GPIO3_A5/UART1_RTSN (Linux pin 101). By doing that I get: vmiceli@nanopineo3:~$ dmesg | grep pps [ 0.463517] pps_core: LinuxPPS API ver. 1 registered [ 0.463528] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 14.338971] pps pps0: new PPS source pps.-1 [ 14.339177] pps pps0: Registered IRQ 60 as PPS source That sees like a great success so far, I finally have the kernel create a /dev/pps0 device and assign an IRQ. However when I go test it with ppstest I get a connection timeout, so something is still not right. vmiceli@nanopineo3:~$ sudo ppstest /dev/pps0 trying PPS source "/dev/pps0" found PPS source "/dev/pps0" ok, found 1 source(s), now start fetching data... time_pps_fetch() error -1 (Connection timed out) time_pps_fetch() error -1 (Connection timed out) time_pps_fetch() error -1 (Connection timed out) The system sees the pin going hi/low as I can run watch -n 1.1 sudo cat /sys/kernel/debug/gpio and the gpio pin assigned to pps goes from hi to low as expected. Any ideas?!? Thanks! Enzo
Solution Igor Posted March 27, 2021 Solution Posted March 27, 2021 On 3/23/2021 at 1:32 PM, vmiceli said: I'm setting up an NTP server on a NanoPi Neo3 board (RK3328) running Armbian Expand On 3/23/2021 at 1:32 PM, vmiceli said: root@DietPiNTP Expand We don't support 3rd party (commercial) projects you are using, sorry. This forum is dedicated to https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-authenticity under those terms https://github.com/armbian/build#support I am sure this doesn't matter to you, but it does to us. We already can't allocate enough resources to support our users, while we never had intention to support others or under some general terms. On 3/23/2021 at 1:32 PM, vmiceli said: Here are the usual reports to show what OS I'm running. Expand It seems you are not (very long) a part of this community, otherwise you would know this forum is not a technical support service and we have a tool for reporting troubles. When you get rid of Dietpi overlay, start here https://www.armbian.com/bugs If this is a feature you are asking for https://forum.armbian.com/forum/38-feature-requests/ waiting time is measured in years.
