Thank you Armbian guys for providing and supporting a working 5.10 image for the Rock Pi 4C board.
Has anyone been successful in configuring and using a matched CSI camera with a 5.x kernel for this board? If so, can you share the required conf steps here?
Radxa's website (https://wiki.radxa.com/Rockpi4/MIPI_Camera) claims that their provided Debian image supports both RPi ov5647 and RPi imx219 based cameras so that confirms hardware compatibility but so far I haven't been able to capture images/video with neither on Armbian when attached to a Rock Pi 4C.
$ ls -l /dev/video*
crw-rw---- 1 root video 81, 0 Apr 3 07:30 /dev/video0
crw-rw---- 1 root video 81, 1 Apr 3 07:30 /dev/video1
crw-rw---- 1 root video 81, 2 Apr 3 07:30 /dev/video2
crw-rw---- 1 root video 81, 3 Apr 3 07:30 /dev/video3
exist,
v4l2-compliance and v4l2-ctl --list-formats-ext work and provide good output.
However, capturing the actual photo doesn't work:
$ fswebcam -d /dev/video0 -r 2048x1536 --jpeg 95 test.jpg
--- Opening /dev/video0...
Trying source module v4l2...
/dev/video0 opened.
No input was specified, using the first.
Unable to query input 0.
VIDIOC_ENUMINPUT: Inappropriate ioctl for device
I had enabled ov5647 manually in /etc/modules
$ lsmod | grep ov
ov5647 20480 0
v4l2_fwnode 28672 1 ov5647
governor_performance 16384 0
videodev 299008 8 rockchip_vdec,v4l2_fwnode,ov5647,videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_common,v4l2_mem2mem
mc 61440 7 rockchip_vdec,videodev,ov5647,videobuf2_v4l2,hantro_vpu,videobuf2_common,v4l2_mem2mem
But still no joy, one gets the dreaded VIDIOC_ENUMINPUT error.
What else am I missing? I’ve seen references to disabling twi2 but I’m unable to find where to make this change in 5.10 if that's indeed the cause.
You need to use the legacy kernel for the camera to work, not current. And you also need to install the multimedia framework:
Remember, you need an Armbian Buster Legacy Desktop image, and install the framework as described in the post.
For last, you need to enable the camera using a overlay:
$ sudo armbian-config
Then select System > Hardware > rpi-cam-imx219
Please post the results of your tests. I have been looking for someone to test the imx219 for a while (I only have a ov5647)  :)
In order to use the imx219 sensor (or any other sensor) in mainline kernel 5.x you need to tell the sensor which format and size the sensor must deliver the frames using v4l2-ctl prior to grabbing the frames.
Something like:
v4l2-ctl --set-subdev-fmt pad=0,width=1280,height=960,code=0x3001 -d /dev/v4l-subdev1
v4l2-ctl --set-subdev-fmt pad=0,width=1280,height=960,code=0x3001 -d /dev/v4l-subdev0
v4l2-ctl --set-subdev-fmt pad=2,width=800,height=600,code=0x2008 -d /dev/v4l-subdev0
Collabora has a complete setup and a patched libcamera where you can pull some images from the sensor in mainline 5.x.
For this, you need an updated rkisp driver and imx219 device node in dts (if you don't have it yet!) and fresh compiled v4l2-ctl.
You can refer to:
https://gitlab.collabora.com/koike/linux/-/commit/7842ca07b75828785ffcd217362a82eaa9cc1e21
You can also refer to the work done here for further information:
https://github.com/initBasti/NanoPC-T4_armbian_configuration#testing-the-camera-
Thanks @JMCC and @@lex for the replies and support.
The reason I was asking about mainline (here 5.10) was because a lot of the OEM legacy kernel distros I've come across have a kernel bug affecting the on-board PCIe M.2 preventing my use case with that connector. The issue was said to have been fixed around mainline 5.8 that's why I tried 5.10 Armbian and it worked for me.
However, the PCIe issue seems to be absent in your 4.4 Debian Buster as well so that's good news, it means that I have two options: I can try the legacy suggestion before having to do patching for 5.10.
Unfortunately with legacy after following the instructions I'm running into issues with both ov5764 and imx219 on Rock PI 4C. Perhaps a hardware configuration oddity with this particular SBC?
dmesg | egrep 'video|ov5'
[    1.467376] Linux video capture interface: v2.00
[    2.360737] ov5647 4-0036: Unsupported clock frequency: 6000000
[    2.360759] ov5647: probe of 4-0036 failed with error -22
[    2.365727] usbcore: registered new interface driver uvcvideo
dmesg | egrep 'video|imx'
[    1.463369] Linux video capture interface: v2.00
[    2.356761] imx219 4-0010: Reading register 100 from 10 failed
[    2.356936] imx219 4-0010: Reading register 100 from 10 failed
[    2.363981] imx219 4-0010: Error -5 setting default controls
[    2.364008] imx219: probe of 4-0010 failed with error -5
[    2.368743] usbcore: registered new interface driver uvcvideo
That's with one corresponding overlay active at any given time.
The error during capture has changed from "VIDIOC_ENUMINPUT: Inappropriate ioctl for device" to "VIDIOC_S_INPUT: Inappropriate ioctl for device"
What else am I missing this time? ;)
Quick Qs @JMCC: will this work with the server version of legacy buster? I prefer the more lightweight server version and won't be displaying a desktop as a target solution. Would I be forced by the framework to install x11/xfce?
Also, is this suggested solution, too, expected to work for OV13850 and Firefly-RK3399?
RK BSP kernel uses a special camera interface (RK-ISP1). The best way to make it work, in my experience, is with the RK GStreamer plugin. In the MM Framework documentation  (1st post) you have a link to the TInkerBoard wiki, where they explain how to use it. The plugin is ready to go when you install the MM Framework.
The media-buster-legacy-rk3399 package will install desktop. You have two options:
1. Disable desktop with "systemctl disable lightdm"
2. Install only the required packages manually without installing the media-buster-legacy-rk3399 metapackage, and probably do some manual config changes.
Option 1. seems easier to me.
Probably so, but I don't own the hardware, nor have developed for it. I am not sure if the necessary kernel configs and DT nodes are present in the kernel. If they are not, you can add them and make a PR.
Cool, thanks, you've confirmed my suspicions.
I retried with buster server 4.4.213, mostly to start from foundation and retrace steps. Installed ok just like before, and still seeing the probe error (-5) in dmesg for imx219. Also, media-ctl -p does not report anything as entity 7. v4l2-compliance and v4l2-ctl --list-formats-ext show expected output, so it doesn't look like electrical conn problems. I'm assuming that since media-ctl output is not as expected, there is no point in trying to validate with gstreamer just yet, something's amiss.
I started building rkisp before posting on this thread, would that be one of the prerequsites now, given all of the above? Is /dev/video0 correctly designated as a "Sink"? I'm starting to think there might be a GPIO mismatch between this board's CSI and tinkerboard's if tinkerboard works.
$ media-ctl -p
Media controller API version 0.1.0
Media device information
driver          rkisp1
model           rkisp1
serial
bus info
hw revision     0x0
driver version  0.0.0
Device topology
- entity 1: rkisp1-isp-subdev (4 pads, 0 link)
            type V4L2 subdev subtype Unknown flags 0
	pad0: Sink
	pad1: Sink
	pad2: Source
	pad3: Source
- entity 2: rkisp1_mainpath (1 pad, 0 link)
            type Node subtype V4L flags 0
            device node name /dev/video0
	pad0: Sink
- entity 3: rkisp1_selfpath (1 pad, 0 link)
            device node name /dev/video1
	pad0: Sink
- entity 4: rkisp1-statistics (1 pad, 0 link)
            device node name /dev/video2
	pad0: Sink
- entity 5: rkisp1-input-params (1 pad, 0 link)
            device node name /dev/video3
	pad0: Source
- entity 6: rockchip-mipi-dphy-rx (2 pads, 0 link)
	pad0: Sink
	pad1: Source
v4l2-compliance SHA: not available, 64 bits
Compliance test for device /dev/video0:
Driver Info:
	Driver name      : rkisp1_v00
	Card type        : rkisp1_mainpath
	Bus info         : platform:ff910000.rkisp1
	Driver version   : 4.4.213
	Capabilities     : 0x84201000
		Video Capture Multiplanar
		Streaming
		Extended Pix Format
		Device Capabilities
	Device Caps      : 0x04201000
		Streaming
		Extended Pix Format
Media Driver Info:
	Model            : rkisp1
	Serial           :
	Bus info         :
	Media version    : 0.1.0
	Hardware revision: 0x00000000 (0)
	Driver version   : 0.0.0
Entity Info:
	Type             : V4L2 I/O
	Pad              : 0: Sink
Required ioctls:
	test MC information (see 'Media Driver Info' above): OK
	test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
	test second /dev/video0 open: OK
	test VIDIOC_G/S_PRIORITY: OK
	test for unlimited opens: OK
Debug ioctls:
	test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
	test VIDIOC_LOG_STATUS: OK (Not Supported)
Input ioctls:
	test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
	test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
	test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
	test VIDIOC_ENUMAUDIO: OK (Not Supported)
		fail: v4l2-test-input-output.cpp(420): G_INPUT not supported for a capture device
	test VIDIOC_G/S/ENUMINPUT: FAIL
	test VIDIOC_G/S_AUDIO: OK (Not Supported)
	Inputs: 0 Audio Inputs: 0 Tuners: 0
Output ioctls:
	test VIDIOC_G/S_MODULATOR: OK (Not Supported)
	test VIDIOC_ENUMAUDOUT: OK (Not Supported)
	test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
	test VIDIOC_G/S_AUDOUT: OK (Not Supported)
	Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
	test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
	test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
	test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
	test VIDIOC_G/S_EDID: OK (Not Supported)
Control ioctls:
	test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
	test VIDIOC_QUERYCTRL: OK
	test VIDIOC_G/S_CTRL: OK
		fail: v4l2-test-controls.cpp(590): g_ext_ctrls does not support count == 0
	test VIDIOC_G/S/TRY_EXT_CTRLS: FAIL
	test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK (Not Supported)
	test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
	Standard Controls: 0 Private Controls: 0
Format ioctls:
		fail: v4l2-test-formats.cpp(273): duplicate format 42474752 (RGGB)
	test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: FAIL
	test VIDIOC_G/S_PARM: OK (Not Supported)
	test VIDIOC_G_FBUF: OK (Not Supported)
		fail: v4l2-test-formats.cpp(330): !colorspace
		fail: v4l2-test-formats.cpp(453): testColorspace(pix_mp.pixelformat, pix_mp.colorspace, pix_mp.ycbcr_enc, pix_mp.quantization)
	test VIDIOC_G_FMT: FAIL
	test VIDIOC_TRY_FMT: OK (Not Supported)
	test VIDIOC_S_FMT: OK (Not Supported)
	test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
		fail: v4l2-test-formats.cpp(1333): doioctl(node, VIDIOC_G_SELECTION, &sel) != EINVAL
	test Cropping: FAIL
	test Composing: OK (Not Supported)
	test Scaling: OK
Codec ioctls:
	test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
	test VIDIOC_G_ENC_INDEX: OK (Not Supported)
	test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls:
	test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: OK
		fail: v4l2-test-buffers.cpp(546): VIDIOC_EXPBUF is supported, but the V4L2_MEMORY_MMAP support is missing, probably due to earlier failing format tests.
	test VIDIOC_EXPBUF: OK (Not Supported)
Total: 44, Succeeded: 39, Failed: 5, Warnings: 0
$ v4l2-ctl --list-formats-ext -d /dev/video0
ioctl: VIDIOC_ENUM_FMT
	Type: Video Capture Multiplanar
	[0]: 'YUYV' (YUYV 4:2:2)
	[1]: '422P' (Planar YVU 4:2:2)
	[2]: 'NV16' (Y/CbCr 4:2:2)
	[3]: 'NV61' (Y/CrCb 4:2:2)
	[4]: 'YM16' (Planar YUV 4:2:2 (N-C))
	[5]: 'NV21' (Y/CrCb 4:2:0)
	[6]: 'NV12' (Y/CbCr 4:2:0)
	[7]: 'NM21' (Y/CrCb 4:2:0 (N-C))
	[8]: 'NM12' (Y/CbCr 4:2:0 (N-C))
	[9]: 'YU12' (Planar YUV 4:2:0)
	[10]: 'YM24' (Planar YUV 4:4:4 (N-C))
	[11]: 'RGGB' (8-bit Bayer RGRG/GBGB)
	[12]: 'GRBG' (8-bit Bayer GRGR/BGBG)
	[13]: 'GBRG' (8-bit Bayer GBGB/RGRG)
	[14]: 'BA81' (8-bit Bayer BGBG/GRGR)
	[15]: 'RGGB' (8-bit Bayer RGRG/GBGB)
	[16]: 'BA10' (10-bit Bayer GRGR/BGBG)
	[17]: 'GB10' (10-bit Bayer GBGB/RGRG)
	[18]: 'BG10' (10-bit Bayer BGBG/GRGR)
	[19]: 'RG12' (12-bit Bayer RGRG/GBGB)
	[20]: 'BA12' (12-bit Bayer GRGR/BGBG)
	[21]: 'GB12' (12-bit Bayer GBGB/RGRG)
	[22]: 'BG12' (12-bit Bayer BGBG/GRGR)
$ v4l2-ctl --list-formats-ext -d /dev/video3
	Type: Video Capture
