[Invalid] - Nanopi R2S : Cpu Freq can only reached 1.30Ghz
Go to solution Solved by Werner,
Current version using Armbian 21.02.3 Focal with Linux 5.10.21-rockchip64
I have tried to edit /etc/default/cpufrequtils :
ENABLE=true
MIN_SPEED=600000
MAX_SPEED=1512000
GOVERNOR=ondemand
Save and run the command :
service cpufrequtils restart
However, the cpu freq only hit the max of 1.30Ghz.
Running the command :
cat /sys/devices/system/cpu/cpu{0,1,2,3}/cpufreq/scaling_available_frequencies
408000 600000 816000 1008000 1200000 1296000
Is it possible to add back 1.5Ghz  or 1.6Ghz  available frequencies for R2S in the next update ?
Thanks in advance !
Your issue report is invalid for one or multiple reasons (non-exhaustive enumeration):
  • it has been stated at the wrong place
  • it lacks fundamental requested data
  • it could have been easily solved by a quick search and/or reading documentation
  • unsupported userspace/image/SBC
Since you refused to use the bug reporting form carefully and follow the information there as you have been asked for we have no intention to further investigate.
Please add missing information if applicable.
https://www.armbian.com/bugs
  • Solution
Enable in armbian-config as overlay
And adjust
cat /etc/default/cpufrequtils
ENABLE=true
MIN_SPEED=408000
MAX_SPEED=1512000
GOVERNOR=ondemand
