MoA Posted April 5, 2021 Posted April 5, 2021 Hello all, I need some help. I have a Beelink GT1 Mini TV Box 64GB Gigabit Lan 4 GB Ram. I use this stock firmware: v007P0 stock firmware LPDDR4 version (SN: 95X2) for Beelink GT1 Mini TV Box from here. https://beelink-my.sharepoint.com/:u:/g/personal/firmwareservice_beelink_onmicrosoft_com/EQ8GFfRPJopFoKLfJt71qyMB7ZuofgTb_L3_VW3CHO2g2g?e=Hq70yf https://chinagadgetsreviews.com/download-android-pie-9-v007p0-stock-firmware-for-beelink-gt1-mini-tv-box.html I am trying to flash Armbian_20.10_Arm-64_buster_current_5.9.0.img.xz using the meson-g12a-gt1-mini-a but I get the error here-below: I have tried all other meson-g12a with same result Is it because it has LPDDR4 instead of DDR4 ? Anything I can do to make it work?? Supported API: 3 charge_status 2, charged 1, status SUCCAESS, capacity 100 Finding update package Opening update package E: Block map file too short: 3 E: Map of '@/cache/recovery/block.map' failed E: failed to map file Installation aborted Thanks a lot in advance for your help, MoA, Cheers,
SteeMan Posted April 9, 2021 Posted April 9, 2021 When you say you are trying to flash Armbian_20.10_Arm-64_buster_current_5.9.0.img.xz what do you mean by that? Specifically what steps are you doing? Are you following the instructions in fhe FAQ: https://forum.armbian.com/topic/17106-installation-instructions-for-tv-boxes-with-amlogic-cpus
MoA Posted April 11, 2021 Author Posted April 11, 2021 Thanks! I followed a different guide which told me to use the "update software" to load the autoscript.sh (this method actually works for my Vorke S912 Z6 Plus). For the S905x2 Beelink GT1 Mini --> It seems that we have to use the toothpick method! Cheers and thanks again.
RicardoSA Posted August 3, 2021 Posted August 3, 2021 Hi, I'm trying to flash a GT1 Ultimate and i seam to be getting stuck at a flashing beelink logo. Changed the extlinux.conf to use the gt1 instead and copyed the gt1 file to the root and renamed it. But the only thing i keep getting is the logo as i plug the power on and then goes away and then some times shows up again in the screen. But that's mainly it... Any tips? Using Armbian_20.10_Arm-64_bullseye_current_5.9.0.img.xz
SteeMan Posted August 3, 2021 Posted August 3, 2021 @RicardoSA What instructions are you following? No current instructions have a step that requires you to copy any file to root. Look at the instructions in the FAQ section of the TV box forum.
RicardoSA Posted August 4, 2021 Posted August 4, 2021 On 8/3/2021 at 6:54 PM, SteeMan said: @RicardoSA What instructions are you following? No current instructions have a step that requires you to copy any file to root. Look at the instructions in the FAQ section of the TV box forum. Expand Was doing a mix of the old way and the way of that method you mentioned read properly and it worked just fine thank you
vcmsptx Posted November 24, 2022 Posted November 24, 2022 Hi, I tried plugin the power on while the reset button is triggered, but after logo it just shutdown (led off).. any idea? This is a GT1mini, using : in extlinux.conf: LABEL Armbian LINUX /zImage INITRD /uInitrd # aml s9xxx FDT /dtb/amlogic/meson-g12a-gt1-mini-a APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 and used in /boot u-boot-s905x2-s922 for u-boot.ext Thanks, VC
SteeMan Posted November 24, 2022 Posted November 24, 2022 @vcmsptx What build and instructions are you using?
vcmsptx Posted November 24, 2022 Posted November 24, 2022 I tried several: Armbian_20.10_Arm-64_buster_current_5.9.0.img.xz Armbian_22.11.0-trunk_Aml-s9xx-box_kinetic_edge_6.0.9.img.xz Armbian_22.11.0-trunk_Aml-s9xx-box_kinetic_edge_6.0.8.img.xz For the instructions, I followed the main faq: https://forum.armbian.com/topic/17106-installation-instructions-for-tv-boxes-with-amlogic-cpus thanks
SteeMan Posted November 25, 2022 Posted November 25, 2022 @vcmsptx with the new builds (i.e. the 6.0.x kernels) try changing the extlinux.conf file to use: LINUX /uImage I noticed an issue that the u-boot currently packaged (u-boot-s905x2-s922) doesn't boot the Image binary but will boot the uImage kernal binary. At least this is the case on my s905x2 based box. If you can confirm this same behavior on your box, that would be helpful.
SteeMan Posted November 25, 2022 Posted November 25, 2022 @vcmsptx Also, there is no meson-g12a-gt1-mini-a dtb file in these builds. Where did you get that? And are you sure you put it in the correct location? Also are you sure that dtb file is compatible with a mainline kernel?
vcmsptx Posted November 26, 2022 Posted November 26, 2022 @SteeManYou are right.. I was using another dtb file as there was no available for s905x2. Meanwhile, I found an old image "Armbian_20.02.0-rc1.038_Aml-s9xxx_eoan_current_5.5.0-rc6_desktop_20200205.img.xz" with meson-g12a-gt1-mini-a.dtb which worked just fine. Thanks!
Andrea Il Bertha Bertini Posted February 25, 2023 Posted February 25, 2023 Hello, I'm really noob with Linux, but I'm trying to learn a bit... I'd like to use my Beelink GT1 Mini with Armbian (than Home assistant on it), can you please share your working IMG so I can flash it and try?
