jarbear Posted April 12, 2021 Posted April 12, 2021 Hello. I have installed openvpn and network-manager. I select Openvpn. I go to create and select automatic. I input my .ovpn file and the save button is greyed. It asks for a PAC Url. But, my vpn provider doesn't use pac urls. Is there away I can get vpn working? Armbian working great. It's a very good operating system. Everything works only vpn is the last one to get working. Armbian running on a tinkerboard. armbianmonitor -U ta. 4517 [ 13.987953] systemd[1]: Started Set console font and keymap. 4518 [ 14.021762] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net> 4519 [ 14.129938] zram: Added device: zram0 I deleted it all so no need to scroll through all of that.
Werner Posted April 13, 2021 Posted April 13, 2021 7 hours ago, jarbear said: openvpn and network-manager. You should ask at their place since both nm and openvpn are userspace packages which Armbian is not involved in. 7 hours ago, jarbear said: armbianmonitor -U Seems incomplete.
jarbear Posted April 13, 2021 Author Posted April 13, 2021 I see but that is what is given in the terminal. I don't know why the first 4000 lines are missing. I checked the endless scrollback in the terminal's preference. Ok I'll check with openvpn.net
Solution jarbear Posted April 13, 2021 Author Solution Posted April 13, 2021 I got vpn working. 1 installed network-manager-openvpn-gnome. 2 went to vpn connections and configure vpn. 3 selected autoConfiguration under the openvpn. 4 inserted my .ovpn file from the service provider. I didn't think network-manager-openvpn-gnome was needed since the network-manager-openvpn was installed. Note: At first the configuration window disappeared. I thought it didn't work. So, I went back to the vpnconnection and saw that it was configured but it was unchecked. I clicked on it and the yellow lock appeared on the network icon on the right side panel. Apps installed openvpn network-manager-openvpn network-manager-openvpn-gnome gadmin-openvn-client gadmin-openvpn-server
