malaga Posted April 15, 2021 Posted April 15, 2021 Hello dear Armbian-experts, first of all - i hope youre all right and everything goes okay in your hometown. i am currently triyng to get started with MQTT-Protocoll. i want to use it with a RaspBerryPi - see here my diagram: +---------------------------------+ | Device 2 | | | -- | --/ | | Subsciber ---/ | | --/ | | --/ +---------------------------------+ --/ ---/ +-----------------------------+ --/ +------------------------------+ | |-/ | device 1: | | | | Publisher | | MQTT - Broker | +---------------------------------+ | | | | | | | intended measures: | | | Subsciber | Device 3 | | -Temperature | | |--------------------------| | | -Light | Message -> | | | | | -Moisture |------------------------| | | | | | | | +---------------------------------+ | | | | | | | | | | | |-\ | | | | ---\ | | | | - ---\ | | | | ---\ +------------------------------+ +-----------------------------+ Subscriber--\ +----------------------------------+ ---\ | | ---\ | Device 4 | -- | | | | | +----------------------------------+ what is planned: according to the diagram that is shown above: device 1 is my publisher and the other devices(2-3) are meant to be the subscribers. i want to do the following: device 1 publishes on a topic “RaspBerryPi/Temperature-measuremet” devices(2-4) are connected and do a subscription The devices subscribe to the same topic - “RaspBerryPi/Temperature-measuremet” In my plan the devices(2-4) are so called "receivers" and the device 1 is a so called a sender. I want to run the raspi as a broker - is that okay!?
Werner Posted April 15, 2021 Posted April 15, 2021 I wonder why you ask this at our place and not on RPi place since Armbian does not deal with RPi whatsoever
arox Posted April 15, 2021 Posted April 15, 2021 21 minutes ago, Werner said: I wonder why you ask this at our place and not on RPi place since Armbian does not deal with RPi whatsoever Well, for once he has a chance to implicate some other armbian SBC as a client ... And in response to the "question", I have been doing this for 4 years with mosquitto (compiled without websocket) and MQTT clients in python, tcl, C, golang ... on raspbian, armbian, debian, RTOS ... So I think it **may** work, as it is designed to do so.
malaga Posted April 16, 2021 Author Posted April 16, 2021 hi there - good day dear Werner, dear Arox, many thanks for the quick reply. I am very glad to hear from you. I have some Orange-Pi here and besides them also a Banana Pi. So - if i am able to get started with the MQTT - protocoll on one device then i surely will implement it on those systems too. I will work it out - more thoroughly Many thanks to you both - for encouraging me. Have a great day. PS - keep up the great work - it rocks!! i am a big big fan of 'Armbian!
