getting started with the MQTT-Protocoll - running raspberry pi as a broker
Hello dear Armbian-experts,
first of all - i hope youre all right and everything goes okay in your hometown.  i am currently triyng to get started with MQTT-Protocoll.
i want to use it with a RaspBerryPi - see here my diagram:
        |       Device 2                  |
        Subsciber      ---/    |                                 |
         |         device 1:            |                        |                             |
         |         Publisher            |                        |       MQTT - Broker         |                          +---------------------------------+
         |     intended measures:       |                        |                             |       Subsciber          |        Device 3                 |
         |       -Temperature           |                        |                             |--------------------------|                                 |
         |       -Light                 |    Message ->          |                             |                          |                                 |
         |       -Moisture              |------------------------|                             |                          |                                 |
         +------------------------------+                        +-----------------------------+    Subscriber--\         +----------------------------------+
        ---\ |      Device 4                    |
what is planned:
according to the diagram that is shown above:
device 1 is my publisher and the other devices(2-3) are meant to be the subscribers.
i want to do the following:
device 1 publishes on a topic “RaspBerryPi/Temperature-measuremet”
devices(2-4) are connected and do a subscription
The devices subscribe to the same topic - “RaspBerryPi/Temperature-measuremet”
In my plan the devices(2-4) are  so called "receivers" and the device 1 is a so called a sender.
I want to run the raspi as a broker - is that okay!?
I wonder why you ask this at our place and not on RPi place since Armbian does not deal with RPi whatsoever :lol:
Expand
Well, for once he has a chance to implicate some other armbian SBC as a client ...
And in response to the "question", I have been doing this for 4 years with mosquitto (compiled without websocket) and MQTT clients in python, tcl, C, golang ... on raspbian, armbian, debian, RTOS ... So I think it **may** work, as it is designed to do so.
hi  there - good day dear Werner, dear Arox,  :)
many thanks for the quick reply. I am very glad to hear from you.
I have some Orange-Pi here and besides them also a Banana Pi. So - if i am able to get started with the MQTT - protocoll on one device then i surely will implement it on those systems too.  I will work it out - more thoroughly
Many thanks to  you both - for encouraging me.
Have a great day.
PS - keep up the great work - it rocks!! i  am a big big fan of 'Armbian!
