regsd Posted August 7, 2016 Share Posted August 7, 2016 I am using ARMBIAN Ubuntu 16.04.1 LTS 4.6.3-cubox on SolidRun HummingBoard-i2eX Dual SoC i.MX6 Dual Single Board Computer. I have an USB 3.0 controller attached to the board (via a PCI slot). As far as I know, xhci_hcd has to be compiled for the controller to function properly. In the default installation, xhci_hcd is disabled ( /boot/config-4.6.3-cubox says: "# CONFIG_USB_XHCI_HCD is not set"). Do I have to setup a complete build environment as descried here http://docs.armbian.com/Developer-Guide_Build-Preparation/ or I can just somehow compile the module on the board itself? Where exactly do I get the sources from? Thanks Link to comment Share on other sites More sharing options...
Igor Posted August 8, 2016 Share Posted August 8, 2016 AFAIK yes. If you not in a rush, I added this and will soon push out a small update & this can be a part of it. Link to comment Share on other sites More sharing options...
regsd Posted August 8, 2016 Author Share Posted August 8, 2016 Thank you, Igor. If you are adding the capability to build individual kernel modules on the board, I can definitely wait for a few days. Link to comment Share on other sites More sharing options...
regsd Posted August 17, 2016 Author Share Posted August 17, 2016 Are there any news? Link to comment Share on other sites More sharing options...
