I have been trying to Build Armbian for a humming board under debian Stretch.
As it will not build directly under Debian I tried building it in an Ubuntu 14.04 container.
I encountered one problem with the most recent Armbian.
I was building in
/usr/src/amp/Armbian
While Building linux the imx 6 sdma build failed as it was unable to access /usr/src/amp/source/....
This was clearly an error as the path should have been /usr/src/amp/Armbian/source/....
I was able to build by symbolic linking the source directory to /usr/src/amp.
The build now completed
However there were warnings
Could not stat /dev/loop0p1 --- No such file or directory
Toward the end - but I can address those.
there are some existing posts on the forum with building in a container that discuss the loopback problem.
Tapatalk thinks its important to tell you im using tapatalk from a phone.
