KodiakFi Posted August 13, 2016 Posted August 13, 2016 Hey Folks, After the Solid-Run screen I lose HDMI, serial works fine of course. Assuming the Cubox can't use my resolutions by default but I have no idea how to fix. Could anyone please point me in the right direction? $ xrandrScreen 0: minimum 320 x 200, current 1920 x 1200, maximum 16384 x 16384VGA-0 disconnected (normal left inverted right x axis y axis)HDMI-0 disconnected (normal left inverted right x axis y axis)DVI-0 connected primary 1920x1200+0+0 (normal left inverted right x axis y axis) 518mm x 324mm 1920x1200 59.95*+ 1920x1080 60.00 1600x1200 60.00 1680x1050 59.88 1280x1024 60.02 1440x900 59.90 1280x960 60.00 1024x768 60.00 800x600 60.32 56.25 640x480 59.94 root@cubox-i:~# cat /etc/armbian-release# PLEASE DO NOT EDIT THIS FILEBOARD=cubox-iID="Cubox i2eX/i4"VERSION=5.14LINUXFAMILY=cuboxBRANCH=next Thanks yall
Igor Posted August 13, 2016 Posted August 13, 2016 Vanilla kernel does not have video driver, headless usage only.
KodiakFi Posted August 13, 2016 Author Posted August 13, 2016 Vanilla kernel does not have video driver, headless usage only. Ah - OK interesting. Thankfully the Cubox for all it's faults has a great serial chip on-board.
