meymarce Posted April 30, 2021 Posted April 30, 2021 I am having the issue that after some time running (like a day). Rebooting results in crashing during kernel loading. Than I have to hardreset the system and it boots. If I reboot right away again, no issue. Spoiler [62387.280373] reboot: Restarting system DDR Version 1.24 20191016 In soft reset SRX channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 928MHZ channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 928 MHz, current 856MHz OUT Boot1: 2019-03-14, version: 1.19 CPUId = 0x0 ChipType = 0x10, 324 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=14910MB FwPartOffset=2000 , 100000 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 SdmmcInit=0 1 StorageInit ok = 68410 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3380ec0 signature is wrong recovery gpt... GPT 0x3380ec0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xe5b60 RunBL31 0x40000 NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.10-armbian (Mar 08 2021 - 14:54:58 +0000) SoC: Rockchip rk3399 Reset cause: RST DRAM: 3.9 GiB PMIC: RK808 SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB MMC: mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Model: Helios64 Revision: 1.2 - 4GB non ECC Net: eth0: ethernet@fe300000 scanning bus for devices... starting USB... Bus usb@fe380000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus dwc3 for devices... cannot reset port 4!? 4 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 Card did not respond to voltage select! switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3278 bytes read in 16 ms (199.2 KiB/s) ## Executing script at 00500000 dev: vdd_log @ vdd-log dev: vdd_center @ DCDC_REG1 Boot script loaded from mmc 0 166 bytes read in 13 ms (11.7 KiB/s) 13851967 bytes read in 1335 ms (9.9 MiB/s) 28582400 bytes read in 2730 ms (10 MiB/s) 81913 bytes read in 43 ms (1.8 MiB/s) 2698 bytes read in 30 ms (86.9 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 Moving Image from 0x2080000 to 0x2200000, end=3de0000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 13851903 Bytes = 13.2 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f51b9000, end f5eeecff ... OK Loading Device Tree to 00000000f513c000, end 00000000f51b8fff ... OK Starting kernel ... [ 28.598426] Internal error: Oops: 96000005 [#1] PREEMPT SMP [ 28.598935] Modules linked in: zfs(POE) zunicode(POE) zzstd(OE) zlua(OE) zcommon(POE) znvpair(POE) zavl(POE) icp(POE) spl(OE) r8152 snd_soc_hdmi_codec snd_soc_rockchip_i2s snd_soc_core leds_pwm snd_pcm_dmaengine panfrost rockchip_vdec(C) hantro_vpu(C) pwm_fan gpio_charger rockchipdrm v4l2_h264 rockchip_rga fusb302 snd_pcm dw_mipi_dsi videobuf2_dma_contig dw_hdmi v4l2_mem2mem gpu_sched tcpm analogix_dp videobuf2_dma_sg videobuf2_vmalloc typec videobuf2_memops drm_kms_helper videobuf2_v4l2 snd_timer cec snd videobuf2_common soundcore rc_core videodev mc drm drm_panel_orientation_quirks sg gpio_beeper cpufreq_dt ledtrig_netdev lm75 ip_tables x_tables autofs4 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear md_mod realtek dwmac_rk stmmac_platform stmmac pcs_xpcs adc_keys [ 28.605559] CPU: 5 PID: 0 Comm: swapper/5 Tainted: P C OE 5.10.21-rockchip64 #21.02.3 [ 28.606343] Hardware name: Helios64 (DT) [ 28.606700] pstate: a0000085 (NzCv daIf -PAN -UAO -TCO BTYPE=--) [ 28.607246] pc : rcu_nmi_enter+0x34/0x150 [ 28.607608] lr : rcu_nmi_enter+0x28/0x150 [ 28.607967] sp : ffff800011c13f30 [ 28.608264] x29: ffff800011c13f30 x28: ffff000040311d00 [ 28.608744] x27: ffff000040004300 x26: ffff800011cf3de0 [ 28.609222] x25: 0000000000000001 x24: 0000000000000000 [ 28.609699] x23: 0000000000000001 x22: ffff80001157de38 [ 28.610177] x21: ffff8000118b99c8 x20: ffff8000e6248080 [ 28.610654] x19: 0000000000000080 x18: 0000000000000000 [ 28.611131] x17: 00028ac100ae65dc x16: 0002e76c96f3d670 [ 28.611608] x15: 00000120adc31936 x14: 00000000000000e9 [ 28.612085] x13: 00000000000000e9 x12: 0000000000000001 [ 28.612562] x11: 0000000000000000 x10: 0000000000000a40 [ 28.613040] x9 : ffff800011cf3e80 x8 : ffff0000403127a0 [ 28.613517] x7 : ffff0000f77c7d80 x6 : 0000000048439f7f [ 28.613994] x5 : 00ffffffffffffff x4 : ffff8000e6248000 [ 28.614471] x3 : 0000000000000001 x2 : ffff80001156a000 [ 28.614948] x1 : ffff8000112a16a8 x0 : ffff8000e6248000 [ 28.615425] Call trace: [ 28.615653] rcu_nmi_enter+0x34/0x150 [ 28.615984] rcu_irq_enter+0x10/0x70 [ 28.616309] irq_enter+0x10/0x20 [ 28.616604] __handle_domain_irq+0x70/0x108 [ 28.616981] gic_handle_irq+0xc0/0x140 [ 28.617320] el1_irq+0xc0/0x180 [ 28.617606] arch_cpu_idle+0x18/0x28 [ 28.617928] default_idle_call+0x44/0x1bc [ 28.618288] do_idle+0x204/0x278 [ 28.618580] cpu_startup_entry+0x28/0x60 [ 28.618935] secondary_start_kernel+0x170/0x180 [ 28.619346] Code: 940000d1 aa1303f4 f8605aa0 8b000294 (f9407e80) [ 28.619897] ---[ end trace 91efb583191134bd ]--- [ 28.620312] Kernel panic - not syncing: Attempted to kill the idle task! [ 28.620908] SMP: stopping secondary CPUs [ 28.621266] Kernel Offset: disabled [ 28.621581] CPU features: 0x0240022,6100200c [ 28.621962] Memory Limit: none [ 28.622250] ---[ end Kernel panic - not syncing: Attempted to kill the idle task! ]--- I used to have quite a few stability issues, which are now all solved with the voltage fix applied. Running stock frequencies with on-demand. Anyone having any ideas? I hope the Kobol team is enjoying some time off though I still see you around. Keep recharging, you really deserve it.
