Raulin Posted May 1, 2021 Posted May 1, 2021 (edited) .I have a Tv Box, with this R329Q V3.0 board, I wanted to know if it is possible to install armbian ... and if this is how the installation procedure is ...... thanks for your help Edited May 1, 2021 by Raulin
SteeMan Posted May 1, 2021 Posted May 1, 2021 5 minutes ago, Raulin said: Tengo una caja Tv Box, con esta placa queria saber si es posible instalar armbian...y si es asi como es el precedimiento de instalacion......gracias por su ayuda... "I have a Tv Box, with this board I wanted to know if it is possible to install armbian ... and if this is how the installation procedure is ...... thanks for your help ..." The armbian forums are in english. Please use google translate.
SteeMan Posted May 1, 2021 Posted May 1, 2021 I believe the brand name of this box is: MXQ 4k which is a rk322x based box. Moving the post to the rockchip tv box forum 1
jock Posted May 2, 2021 Posted May 2, 2021 First of all: https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first Then, all you may need is there: https://forum.armbian.com/topic/12656-csc-armbian-for-rk322x-tv-boxes/
