Hallo,
I hope the topic hasn't existed before ..
I have an Bananpi M2+ as H5 (64bit). Good Images are OrangePi-PC2 or NanoPi K1 Plus. My problem is, no support of emmc.
Are there any known compatible images for the Banana Pi M2 + H5 that work?
The NanoPi K1 Plus has problems rebooting and recognizing a keyboard. The OranngeP PC2 works fine, but no emmc support.
Thanks and
Best wishes,
Mahdi2006
Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs).  With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported.  Your report is invalid for one or more of the following reasons (non-exhaustive list):
  • it is for an unsupported board or image (CSC/EOS/WIP/edge)
  • it is for software that is not supported (such as userspace modules installed on top of the core operating system)
  • it has been logged in the wrong forum (for example requests for help that are not actual bug reports)
  • it lacks requested data (armbianmonitor output)
  • it could have been easily solved by a quick search and/or reading documentation
Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat)
