bob_janes Posted May 17, 2021 Posted May 17, 2021 Hi: I recently installed Buster xfce desktop on Cubox i4pro. Everything works great, except I can not power off cubox. I tried various commands, shutdown -h now; systemctl poweroff; and hatl; but the system first appears to halt, where I can not ping the ip addrss of cubox, but then it reboots. Is there some way to powerfoff cubox? My current system is nightly, but I also tried stable with latest kernel. $ uname -r 5.10.21-imx6 $ cat /etc/os-release PRETTY_NAME="Armbian 21.08.0-trunk.26 Buster"
Werner Posted May 18, 2021 Posted May 18, 2021 Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs). With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported. Your report is invalid for one or more of the following reasons (non-exhaustive list): it is for an unsupported board or image (CSC/EOS/WIP/edge) it is for software that is not supported (such as userspace modules installed on top of the core operating system) it has been logged in the wrong forum (for example requests for help that are not actual bug reports) it lacks requested data (armbianmonitor output) it could have been easily solved by a quick search and/or reading documentation Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat)
bob_janes Posted May 18, 2021 Author Posted May 18, 2021 Sorry, I did not mean to post this as a bug report. I thought I posted it in NXP freescale forum to get some help. I will try again. By the way, I did quite a bit search on this topic both within armbian and on google with not much help.
