technicalitch500 Posted May 22, 2021 Posted May 22, 2021 Hi, I use Armbian on an SBC as an airgapped device with no connection to the internet. Each time I use the device I want to set the correct date and time, I can't work out I do this manually. Any help greatfully received.
guidol Posted May 22, 2021 Posted May 22, 2021 use date like date MMDDhhmmCCYY MM Monthnumber DD Daynumber hh hours mm minutes CC Century YY Year date 052211382021 for 05/22/2021 11:38
technicalitch500 Posted May 22, 2021 Author Posted May 22, 2021 Thanks Guidol, I should probably have added that I'm a newbie and only have very basic knowledge of command line... is there a way to manually set date/time in the GUI? Otherwise how would I set in the CLI?
