I am trying to flash debian jessie  4.x to NAND( there is already wheezy there ), but it doesn't come up in the ./nand-sata-install device list.
I would install wheezy, but the problem is that it is not working( not 3.x or 4.x ), I just get a black screen after Staring Kernel message and the green LED is flashing every few seconds.
What should I try next?
Thank you,
Stefan
- NAND is supported only in kernel 3.4.x. No info when and if will be supported in 4.x
- screen output from kernel is set to HDMI by default. Boot loader can detect and switch, kernel not.
Igor may I ask you to add that info (again) to the Cubietruck Vaniilas "Bugs or limitation" section. Thx!
And another 'usability' hint. At the top of your page you list the various versions twice per legacy / vanilla (e.g. Debian wheezy). However me using FF I have to hover over every link to see the differences (e.g. Armbian_4.2_Cubietruck_Debian_wheezy_3.4.108.zip vs Armbian_4.3_Cubietruck_Debian_wheezy_3.4.108.zip)
Added to bugs sections.
The download page is not determined yet and I haven't come out with a proper solution yet.
Main problem is that there are many different downloads and a download link to previous versions (4.2) is also not that bad, but it has to be solved differently. Now is a bit confusing, I agree.
