skidoo Posted June 8, 2021 Posted June 8, 2021 On Armbian installed from Armbian_21.05.1_Bananapi_buster_current_5.10.34.img.xz on my Banana Pi (first version) install of liburing-dev fails. # apt-get install liburing-dev Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: liburing-dev : Depends: linux-libc-dev (>= 5.1) but 4.19.181-1 is to be installed E: Unable to correct problems, you have held broken packages. Any help?
Solution Werner Posted June 8, 2021 Solution Posted June 8, 2021 Upstream package, therefore most likely Debian issue.
skidoo Posted June 9, 2021 Author Posted June 9, 2021 Ouch. liburing-dev is in case of Debian buster a backport. Installing backport of linux-libc6-dev solved the issue.Case closed. Sorry for the noise..
