tgillett Posted June 17, 2021 Share Posted June 17, 2021 Hi All I am not able to run Armbian Buster from the Downloads page (https://www.armbian.com/cubietruck/) on the CT board. Other images run fine, including: - Armbian_5.65_Cubietruck_Debian_stretch_next_4.14.78 (from archive) - Armbian_5.65_Cubietruck_Ubuntu_bionic_next_4.14.78 (from archive) - openwrt-19.07.7-sunxi-cortexa7-sun7i-a20-cubietruck-squashfs-sdcard.img.gz (from OpenWrt downloads site) The problem is that it endlessly reboots after resetting the CPU. The output from the serial port is shown below. I can interrupt the Autoboot and get to the Uboot console ok. The output from printenv is also shown below. Any suggestions as to what might be the problem would be greatly appreciated. If anyone has this set up working, a copy of the printenv output would be great to compare. Thanks in advance for any help. T Spoiler --------------------------------------------------------------------------- U-Boot SPL 2021.04-armbian (May 06 2021 - 17:01:36 +0000) DRAM: 2048 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2021.04-armbian (May 06 2021 - 17:01:36 +0000) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: Cubietech Cubietruck I2C: ready DRAM: 2 GiB MMC: mmc@1c0f000: 0, mmc@1c12000: 1 Loading Environment from FAT... Card did not respond to voltage select! : -110 Setting up a 1024x768 vga console (overscan 0x0) In: serial Out: vga Err: vga Allwinner mUSB OTG (Peripheral) Net: eth0: ethernet@1c50000, eth1: usb_ether 230454 bytes read in 14 ms (15.7 MiB/s) starting USB... Bus usb@1c14000: USB EHCI 1.00 Bus usb@1c14400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c14000 for devices... 1 USB Device(s) found scanning bus usb@1c14400 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 1 USB Device(s) found scanning bus usb@1c1c400 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3967 bytes read in 2 ms (1.9 MiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 154 bytes read in 2 ms (75.2 KiB/s) 9931076 bytes read in 546 ms (17.3 MiB/s) 7973464 bytes read in 439 ms (17.3 MiB/s) Found mainline kernel configuration 43983 bytes read in 6 ms (7 MiB/s) 5532 bytes read in 4 ms (1.3 MiB/s) Applying kernel provided DT fixup script (sun7i-a20-fixup.scr) ## Executing script at 45000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 9931012 Bytes = 9.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. data abort pc : [<bef89cec>] lr : [<00000011>] reloc pc : [<4a013cec>] lr : [<8b08a011>] sp : baf4aa18 ip : bfd00000 fp : befdd678 r10: 00000020 r9 : baf55ec0 r8 : befea28c r7 : 6c616972 r6 : 00000010 r5 : 275b15ca r4 : baf9ac50 r3 : baf9ac58 r2 : baf9ac48 r1 : baf9d320 r0 : 00000019 Flags: nzCv IRQs off FIQs off Mode SVC_32 (T) Code: d005 f027 0501 441d (686d) 07ed Resetting CPU ... resetting ... ------------------------------------------- Spoiler => version U-Boot 2021.04-armbian (May 06 2021 - 17:01:36 +0000) Allwinner Technology arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025 GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209 => => printenv arch=arm baudrate=115200 board=sunxi board_name=sunxi boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr} boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootarm.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi boot_efi_bootmgr=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr;fi boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf} boot_net_usb_start=usb start boot_prefixes=/ /boot/ boot_script_dhcp=boot.scr.uimg boot_scripts=boot.scr.uimg boot.scr boot_syslinux_conf=extlinux/extlinux.conf boot_targets=fel mmc_auto scsi0 usb0 pxe dhcp bootcmd=run distro_bootcmd bootcmd_dhcp=setenv devtype dhcp; run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00010:UNDI:003000;setenv bootp_arch 0xa;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci; bootcmd_fel=if test -n ${fel_booted} && test -n ${fel_scriptaddr}; then echo '(FEL boot)'; source ${fel_scriptaddr}; fi bootcmd_mmc0=devnum=0; run mmc_boot bootcmd_mmc1=devnum=1; run mmc_boot bootcmd_mmc_auto=if test ${mmc_bootdev} -eq 1; then run bootcmd_mmc1; run bootcmd_mmc0; elif test ${mmc_bootdev} -eq 0; then run bootcmd_mmc0; run bootcmd_mmc1; fi bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi bootcmd_scsi0=devnum=0; run scsi_boot bootcmd_usb0=devnum=0; run usb_boot bootdelay=1 bootm_size=0xa000000 console=ttyS0,115200 cpu=armv7 dfu_alt_info_ram=kernel ram 0x42000000 0x1000000;fdt ram 0x43000000 0x100000;ramdisk ram 0x43300000 0x4000000 distro_bootcmd=scsi_need_init=; for target in ${boot_targets}; do run bootcmd_${target}; done efi_dtb_prefixes=/ /dtb/ /dtb/current/ eth1addr=de:ad:be:ef:00:01 ethaddr=02:4c:03:41:39:15 fdt_addr_r=0x43000000 fdtcontroladdr=baf4bd80 fdtfile=sun7i-a20-cubietruck.dtb fileaddr=66000000 filesize=38436 kernel_addr_r=0x42000000 load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile} loadsplash= for prefix in ${boot_prefixes}; do if test -e mmc 0 ${prefix}boot.bmp; then load mmc 0 ${splashimage} ${prefix}boot.bmp; bmp d ${splashimage}; fi; done mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi mmc_bootdev=0 partitions=name=loader1,start=8k,size=32k,uuid=${uuid_gpt_loader1};name=loader2,size=984k,uuid=${uuid_gpt_loader2};name=esp,size=128M,bootable,uuid=${uuid_gpt_esp};name=system,size=-,uuid=${uuid_gpt_system}; preboot=run loadsplash; usb start pxefile_addr_r=0x43200000 ramdisk_addr_r=0x43300000 scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi; scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done; setenv devplist scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;run boot_efi_bootmgr;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootarm.efi; then echo Found EFI removable media binary efi/boot/bootarm.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done scriptaddr=0x43100000 scsi_boot=run scsi_init; if scsi dev ${devnum}; then devtype=scsi; run scan_dev_for_boot_part; fi scsi_init=if ${scsi_need_init}; then scsi_need_init=false; scsi scan; fi serial#=1651664c03413915 soc=sunxi splashimage=66000000 splashpos=m,m stderr=serial,vga stdin=serial,usbkbd stdout=serial,vga usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi usbnet_devaddr=de:ad:be:ef:00:01 uuid_gpt_esp=c12a7328-f81f-11d2-ba4b-00a0c93ec93b uuid_gpt_system=69dad710-2ce4-4e3c-b16c-21a1d49abed3 Environment size: 5201/131068 bytes => 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 17, 2021 Share Posted June 17, 2021 4 hours ago, tgillett said: Any suggestions as to what might be the problem would be greatly appreciated. https://armbian.atlassian.net/browse/AR-749 Probable cause is that one of the files (dtb, image, ramdisk) are overlapping which means same kernel version (that is smaller) boots, while a bit more features not. Problem is known for months, but our resources are only a tiny fraction needed to keep up with problems that pops up. If you find out right numbers / fix the problem (for everyone) https://docs.armbian.com/Process_Contribute/ Before you start, check self created image (https://github.com/armbian) - perhaps its already fixed. 0 Quote Link to comment Share on other sites More sharing options...
tgillett Posted June 18, 2021 Author Share Posted June 18, 2021 Hi Igor Thanks very much for your response. This is my first day working with Armbian so it is still something of a learning curve. I took your advice and set up the build environment and built images for CT with combinations of Current and Legacy versions of the software for Buster and Focal as supported by the tool. None of these versions would boot correctly, failing in the same manner as the version on the Download page for CT: "Armbian_21.05.1_Cubietruck_buster_current_5.10.34_xfce_desktop" These images all have "U-Boot 2021.04" in common. (U-Boot 2021.04-armbian (May 06 2021 - 17:01:36 +0000)) I don't know how to proceed further with debugging, in particular checking for file sizes as you suggested. I have looked through the documentation Developer Guide / Building Armbian and User Configurations, and through the build files system, but it is not obvious where this information might be, or how to re-configure. Obviously I am missing something basic... I also explored the archive software a little more. The most recent version I could find there was: Armbian_21.02.3_Cubietruck_focal_current_5.10.21 dated March 2021. This software booted correctly, with "U-Boot 2020.10-armbian" I also tested several earlier versions with U-Boot 2019.04 and 2019.01 and they also booted correctly. So I thought it might be worth looking at the environment settings for the different U-Boot versions. Looking through the printenv output for the two recent versions of U-Boot, there are not a lot of obvious differences in address settings. One difference I noticed is the value of the "fdtcontroladdr" setting, as shown below, but I don't know if it is telling us anything useful. U-Boot 2020.10 fdt_addr_r=0x43000000 fdtcontroladdr=baf4ddf0 ### fdtfile=sun7i-a20-cubietruck.dtb fileaddr=66000000 filesize=38436 U-Boot 2021.04 fdt_addr_r=0x43000000 fdtcontroladdr=baf4bd80 ### fdtfile=sun7i-a20-cubietruck.dtb fileaddr=66000000 filesize=38436 I am happy to spend some more time on debugging if I can get some pointers in the right direction. Regards Terry 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 18, 2021 Share Posted June 18, 2021 27 minutes ago, tgillett said: So I thought it might be worth looking at the environment settings for the different U-Boot versions I doubt that has changed, but possible. There are some default values, but we overwrite those with our boot script: https://github.com/armbian/build/blob/master/config/bootscripts/boot-sunxi.cmd Here you could experiment with values. Each time you edit /boot/boot.cmd you need to convert it to boots.scr https://github.com/armbian/build/blob/master/config/bootscripts/boot-sunxi.cmd#L92 You can also override number by editing /boot/armbianEnv.txt which is plain text file. I am not sure my prediction stands. Its just a hunch worth working on. And this problem is not directly related to Armbian (tools) so you will not find any documentation on this topics there. Perhaps here https://linux-sunxi.org/U-Boot or within u-boot documentation in the code or by looking into the code. That's how our world looks like ... 0 Quote Link to comment Share on other sites More sharing options...
tgillett Posted June 18, 2021 Author Share Posted June 18, 2021 Thanks, I'll take a further look. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted July 3, 2021 Share Posted July 3, 2021 @tgillett We will implement this workaround for now. 0 Quote Link to comment Share on other sites More sharing options...
tgillett Posted July 14, 2021 Author Share Posted July 14, 2021 Hi Igor Thanks for the update. I would like to test this solution on CubieTruck board. What do I need to do to get an updated image please? Thanks Terry 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted July 14, 2021 Share Posted July 14, 2021 There are more ways: 1. Wait for our next release, when images are rebuild, tested and fixed for other possible problems https://docs.armbian.com/Process_Release-Model/ 2. Easy DIY - build your custom image by using our build tools. Workaround is already applied there https://github.com/armbian/build 3. Harder DIY Clone boot loader, find instructions for changing it and apply to the image from download section / your not very well working system on your SD card. We also provide nightly images, but u-boot is not rebuilt each time - we use the one we have build before. A task is open on this topic, just time to code and test that needs to happen. 0 Quote Link to comment Share on other sites More sharing options...
tgillett Posted July 14, 2021 Author Share Posted July 14, 2021 I updated my build environment and made a new build for CubieTruck using Buster minimal. Booted the board multiple times and works every time. Thanks for your help. 1 Quote Link to comment Share on other sites More sharing options...
