Need help for installing nvme on RockPi4
Go to solution Solved by Frank13,
  • Solution
Hi everybody,
I am searching for help with my nvme ssd on my RockPi4 - I am a beginner in linux...
I tried several things but now i am stuck...
The hardware seems to work - sudo blkid gives
/dev/mmcblk2p1: UUID="f64fc0b4-7660-4994-b713-880dd6b7886a" TYPE="ext4" PARTUUID="e3470912-01"
/dev/zram0: UUID="b4882aaf-3711-42e2-90e4-146c40ebc73d" TYPE="swap"
/dev/zram1: LABEL="log2ram" UUID="60c2c56f-19a4-45c0-83e4-a6007431733d" TYPE="ext4"
/dev/mmcblk2: PTUUID="e3470912" PTTYPE="dos"
/dev/nvme0n1: UUID="39789eff-ad29-4a45-9f4d-d260fe385ebf" TYPE="ext4" PTUUID="baf98b46" PTTYPE="dos"
/dev/nvme0n1p1: PARTUUID="baf98b46-01"
I also added a line in the /etc/fstab:
UUID=39789eff-ad29-4a45-9f4d-d260fe385ebf /media/nvmssd ext4 default 0 0
But when i try sudo mount-a i always get an error:
mount: /media/nvmssd: wrong fs type, bad option, bad superblock on /dev/nvme0n1p1, missing codepage or helper program, or other error.
I simply dont know how to solve the problem...
Hi everybody,
The problem is solved... I think the reason for the problem was an error on the boot-EMMC in the RockPi. The system crashed and was not able to reboot. After i replaced the EMMC ( I made a copy of it before installing the SSD), I tried again and it worked...
Thanks!
