Hi all,
been trying to sort out a stability problem with what was a rock solid helios64, i moved from running armbian on the eMMC to a 256GB sandisk extreme SD card due to plex continually filling it up.
currently running  Armbian 21.05.6 Buster with Linux 5.10.43-rockchip64, running OMV, Plex and ZFS not much more
it appears this is where things go pear shaped:
  Reveal hidden contents
I've aready given i a bump in voltage as recommended in the config file but i cant tell where to check if it  took the settting, frequency is set in armbian-config to ondemand.
does anyone have any ideas?
Thanks in advance
Krita
Edited by Krita
formatting
apparently my searching skills are rubbish, found a thread with the FPDMA QUEUED fault, will investigate that, but seems thats a seperate isue to the reboot.
So Ive had the crash happen again after allmost exactly 24hrs, this time with logging verbose 5 so i actually got a bit of data. this was under no load at all, no one logged on just a single PC on the network running USB-C serial logging.
I have no idea how to interoperate the data but I'm instigating what it means to the best of my ability, any pointer would be great
