update in buster is failing with redirection from https to 'http://armbian.tnahosting.net/apt/dists/buster/Release' is forbidden
Go to solution Solved by lanefu,
I've tried without and with --no-allow-insecure-repositories and --allow-unauthenticated
Cert issue on the remote?
ns1@ns1:~$ sudo apt-get update
Hit:1 http://security.debian.org buster/updates InRelease
Hit:2 http://httpredir.debian.org/debian buster InRelease
Hit:3 http://httpredir.debian.org/debian buster-updates InRelease
Ign:4 https://apt.armbian.com buster InRelease
Err:5 https://apt.armbian.com buster Release
  Redirection from https to 'http://armbian.tnahosting.net/apt/dists/buster/Release' is forbidden [IP: 173.45.128.12 443]
Reading package lists... Done
E: The repository 'https://apt.armbian.com buster Release' no longer has a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
ns1@ns1:~$ sudo apt-get update --no-allow-insecure-repositories
ns1@ns1:~$ sudo apt-get update --allow-unauthenticated
ns1@ns1:~$
yeah sorry about the trouble.. I/we had some bad defaults with that, and I had changed them on the direct server,  and I think your older install at the apt setup that way.
Lol i got a lot of feedback about https being an undesirable default.    Major reason being those on small connections heavilly rely on caching proxies to make life better.
And yes persisting protocol based on request would be ideal.  How are you at python?
https://github.com/armbian/dl-router/issues/2
Same script, one for http mirrors (port 80) and one for https mirrors (port 443).
I would say same script, but changing the list to not include scheme, and then prepend scheme of client request to target mirror: https://github.com/armbian/dl-router/blob/master/app/mirrors.yaml
I also see that mirrors.netix.net entry is with HTTP, but it has forced redirect to HTTPS, at least after receiving the HSTS header once.
I'm learning Python by doing little contributions here and there, so I'll have a look if I can add this feature :).
