gtludwig Posted August 3, 2021 Posted August 3, 2021 Hi, I have this great tiny SBC without being used because I could not get its fan temperature dependent on dietpi and really did not liked the stock image, so I have been looking for something more interesting. After installing lm-sensors, I ran sensors-detect as root and no sensors were found. I know I saw a temperature readout (calculated?) somewhere and I wonder if whether is possible to have a PWM control of the fan as the stock image does. All help and suggestions are much appreciated. Cheers, Gus
Igor Posted August 3, 2021 Posted August 3, 2021 2 hours ago, gtludwig said: as the stock image does Functions that works on stock kernel (image) can be relatively easily copied from presentation stock image or its derivatives, but if you want to have the same with a quality up2date kernel, serious work and costs could be needed / comes with. I assume components for this feature exist in modern kernel, "just" lacks implementation and maintenance. Like many other common troubles. 2 hours ago, gtludwig said: After installing lm-sensors, I ran sensors-detect as root and no sensors were found. In our nonstandard non mainstream (ARM single board computers) world, such generic tools might not just work. We are using this, to get some common grounds: https://github.com/armbian/build/blob/master/packages/bsp/common/usr/lib/armbian/armbian-hardware-monitor#L22-L56 ... to display board temperature when you login: https://github.com/armbian/build/blob/master/packages/bsp/common/etc/update-motd.d/30-armbian-sysinfo#L50-L65 2 hours ago, gtludwig said: All help and suggestions https://github.com/cgomesu/nanopim4-satahat-fan This script handles it for RK3399, which is similar chip but different enough that it won't just work, but it can give you an idea where & how to start. IIRC it also works on modern kernel without much adjustments: Check if you can contribute on our common agenda: https://forum.armbian.com/forum/54-help-wanted/
