YuzuponShioaji Posted August 9, 2021 Posted August 9, 2021 There is nothing about version information on the NVIDIA Jetson Nano page, and the image is from A02. Can this image also be used with B01?
Solution Werner Posted August 9, 2021 Solution Posted August 9, 2021 Quote B0x images will work on A02 boards without issue. There are some pinmux differences between the two hardware revisions, but the B0x pinmux settings will work fine on an A02 board. However, A0x pinmux (dtb) does not work on B0x board. https://www.arducam.com/nvidia-jetson-nano-b01-update-dual-camera/#jetson-nano-b01-vs-a02-changes If this is true for Armbian no idea since it is CSC. 1
angelicarce Posted August 24, 2021 Posted August 24, 2021 Thank you so much! I'll check out the link.
