ChrisO Posted August 10, 2021 Posted August 10, 2021 Hi I have Odroidhc4 with the following kernel: root@odroidhc4:/opt# uname -a Linux odroidhc4 5.13.9-meson64 #trunk.114 SMP PREEMPT Mon Aug 9 01:19:39 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux Installed from: Armbian_21.08.0-trunk.116_Odroidhc4_hirsute_edge_5.13.9.img And I'm missing ZFS modules. root@odroidhc4:/opt# dpkg -L linux-modules-5.11.0-25-generic | grep zfs /lib/modules/5.11.0-25-generic/kernel/zfs /lib/modules/5.11.0-25-generic/kernel/zfs/icp.ko /lib/modules/5.11.0-25-generic/kernel/zfs/spl.ko /lib/modules/5.11.0-25-generic/kernel/zfs/zavl.ko /lib/modules/5.11.0-25-generic/kernel/zfs/zcommon.ko /lib/modules/5.11.0-25-generic/kernel/zfs/zfs.ko /lib/modules/5.11.0-25-generic/kernel/zfs/zlua.ko /lib/modules/5.11.0-25-generic/kernel/zfs/znvpair.ko /lib/modules/5.11.0-25-generic/kernel/zfs/zunicode.ko /lib/modules/5.11.0-25-generic/kernel/zfs/zzstd.ko root@odroidhc4:/opt# apt-cache search linux-modules-5.13 root@odroidhc4:/opt# dpkg -l | grep linux-modules ii linux-modules-5.11.0-25-generic 5.11.0-25.27 arm64 Linux kernel extra modules for version 5.11.0 on ARMv8 SMP I feel lost and would be gratefull for any assistance. Regards Chris
ChrisO Posted August 10, 2021 Author Posted August 10, 2021 I had them already installed. Reinstalled with armbian-config, no change. I'm missing the zfs modules which, if I understand correctly, are provided by linux-modules* and I cannot find linux-modules. root@odroidhc4:~# ls /lib/modules/5.13.9-meson64/kernel/ arch crypto drivers fs kernel lib net sound
Igor Posted August 10, 2021 Posted August 10, 2021 1 hour ago, ChrisO said: if I understand correctly Nope. Armbian is not Canonical. You should do some forum search - there are many happy ZFS users around here. Me included. sudo apt install zfsutils-linux zfs-dkms ... but unfortunately there is a bug in headers which needs some time. That is on you to fix or wait ... but it can take months since bug is with us also months. Workaround is using stable kernels (current). You can switch to them within armbian-config, install headers there and install dkms package again.
Igor Posted August 11, 2021 Posted August 11, 2021 There is more info in this task: https://armbian.atlassian.net/browse/AR-828
ChrisO Posted August 11, 2021 Author Posted August 11, 2021 OK, trying from scratch: 1. Installed current image: Armbian_21.05.4_Odroidhc4_buster_current_5.10.43.img.xz 2. apt update got some of those recently quite famous "Hash Sum mismatch" *) errors: Err:19 http://mirrors.netix.net/armbian/apt buster/main arm64 linux-image-current-meson64 arm64 21.05.8 Hash Sum mismatch Hashes of expected file: - SHA512:992fe660df2fafcd5487bd613c87bc8d0e5d01d95c9ca26e3385c964934b3e8517ef71b83e7a0830636172ebbac1831a8c1ed872b513730b4ed9068589aa0a9c - SHA256:bf1396f7dba17c053a7ba42958bd65751e06a3921958669fe63f057e522f3a99 - SHA1:f2a4bad1df0353b8fcc1d111d5bdcc520be98ae7 [weak] - MD5Sum:a2a292c3a27617e6aa0e4877637c5a14 [weak] - Filesize:43238688 [weak] Hashes of received file: - SHA512:595cb6dc4c711e3c86c220dc9342a843232903b2529317a5333ac359f9f92205b1fc36023eaeaa322140a7eabce3670425a096718cc71a8881893bc80be4c79f - SHA256:57519afde133640572833f5e4845a75a0ba840e4f529ab6e73815b2004942e62 - SHA1:050d4f43d1f58755af9e702d5a769cef5ea70639 [weak] - MD5Sum:5830178161646bc59ffafa454931425f [weak] - Filesize:43238688 [weak] Last modification reported: Mon, 09 Aug 2021 13:25:41 +0000 Fetched 73.2 MB in 1min 20s (911 kB/s) E: Failed to fetch http://mirrors.netix.net/armbian/apt/pool/main/l/linux-5.10.57-meson64/linux-image-current-meson64_21.05.8_arm64.deb Hash Sum mismatch Hashes of expected file: - SHA512:992fe660df2fafcd5487bd613c87bc8d0e5d01d95c9ca26e3385c964934b3e8517ef71b83e7a0830636172ebbac1831a8c1ed872b513730b4ed9068589aa0a9c - SHA256:bf1396f7dba17c053a7ba42958bd65751e06a3921958669fe63f057e522f3a99 - SHA1:f2a4bad1df0353b8fcc1d111d5bdcc520be98ae7 [weak] - MD5Sum:a2a292c3a27617e6aa0e4877637c5a14 [weak] - Filesize:43238688 [weak] Hashes of received file: - SHA512:595cb6dc4c711e3c86c220dc9342a843232903b2529317a5333ac359f9f92205b1fc36023eaeaa322140a7eabce3670425a096718cc71a8881893bc80be4c79f - SHA256:57519afde133640572833f5e4845a75a0ba840e4f529ab6e73815b2004942e62 - SHA1:050d4f43d1f58755af9e702d5a769cef5ea70639 [weak] - MD5Sum:5830178161646bc59ffafa454931425f [weak] - Filesize:43238688 [weak] Last modification reported: Mon, 09 Aug 2021 13:25:41 +0000 E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? Tried again and it worked, go figure why. 3. apt upgrade This upgraded the kernel to 5.10.57-meson64 4. apt install linux-headers-current-meson64 5. apt install zfsutils-linux zfs-dkms ZFS is there. *) Recently, few weeks ago, most of my Debian based systems started to fail on "apt update" with this "Hash Sum mismatch" error. Cannot figure out what the problem is. The "solution nr. 1" fro google, rm -rf /var/cache/apt/* /var/lib/apt/lists/* doesn't help.
Igor Posted August 11, 2021 Posted August 11, 2021 30 minutes ago, ChrisO said: Cannot figure out what the problem is. https://forum.armbian.com/search/?q=Hash Sum mismatch&quick=1 We need to extend repository index synchronisation timeout from 1 day to several days since mirrors doesn't get in sync in this time frame. The problem is that current main rsync server is slow (only 50Mbps upload in total), but is cheap and has no traffic limits. We know how to solve this, but we lack time: https://armbian.atlassian.net/browse/AR-789
