(Orange Pi PC | 21.02.3 | 5.10.21-sunxi) /dev/cedar_dev not exists
lam96pt
Armbianmonitor:  http://ix.io/3vLl
I try to use FFmpeg with cedrus264 but failed. Error is:
sudo ffmpeg-3.1.4 -f v4l2 -channel 0 -video_size 1280x720 -i /dev/video0 -pix_fmt nv12 -r 22 -qp 30 -c:v cedrus264 -c:a None night_video_test4_1920x1080.mp4
[sudo] password for lam:
ffmpeg version 3.1.4 Copyright (c) 2000-2016 the FFmpeg developers
  built with gcc 4.8 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.3)
  configuration: --prefix=/usr --enable-nonfree --enable-gpl --enable-version3 --enable-vdpau --enable-libx264 --enable-libmp3lame --enable-libpulse --enable-libv4l2 --enable-libcedrus264
  libavutil      55. 28.100 / 55. 28.100
  libavcodec     57. 48.101 / 57. 48.101
  libavformat    57. 41.100 / 57. 41.100
  libavdevice    57.  0.101 / 57.  0.101
  libavfilter     6. 47.100 /  6. 47.100
  libswscale      4.  1.100 /  4.  1.100
  libswresample   2.  1.100 /  2.  1.100
  libpostproc    54.  0.100 / 54.  0.100
Input #0, video4linux2,v4l2, from '/dev/video0':
  Duration: N/A, start: 109.484156, bitrate: 147456 kb/s
    Stream #0:0: Video: rawvideo (YUY2 / 0x32595559), yuyv422, 1280x720, 147456 kb/s, 10 fps, 10 tbr, 1000k tbn, 1000k tbc
File 'night_video_test4_1920x1080.mp4' already exists. Overwrite ? [y/N] y
[cedrus264 @ 0x16e0060] VE Open error.
Output #0, mp4, to 'night_video_test4_1920x1080.mp4':
    Stream #0:0: Unknown: none
    Metadata:
      encoder         : Lavc57.48.101 cedrus264
Stream mapping:
  Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (cedrus264))
Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
Maybe the reason is  /dev/cedar_dev not exists in my system. I found this intruction  but I don't know what i need to do. Please help me!  Thanks all !
  • lam96pt changed the title to (Orange Pi PC | 21.02.3 | 5.10.21-sunxi) /dev/cedar_dev not exists
