shijieteo Posted September 20, 2021 Posted September 20, 2021 Armbianmonitor: http://ix.io/3zoC I am using a NanoPi R1S-H3 that runs on the Allwinner-H3 CPU: https://www.friendlyarm.com/index.php?route=product/product&product_id=274. I flashed a copy of Armbian 21.08.1, Buster current 5.10.60 for the NanoPi R1, which has a similar H3 chip. The R1S-H3 has an onboard SDIO Wi-Fi card that requires the RTL8189ES drivers, which I have loaded in already. Unfortunately, I am unable to use the Wi-Fi card on the device. I did notice an error: "mmc2: error -22 while initializing SDIO card" which might be the cause. However, I am not too sure on how to go about resolving it. Any suggestions? Thanks in advance
Solution Werner Posted September 20, 2021 Solution Posted September 20, 2021 R1 != R1S Both boards may have a different WiFi Chip and therefore the device tree may not fit.
shijieteo Posted September 21, 2021 Author Posted September 21, 2021 If I were to go about editing the device tree, where/what should I be looking out for and editing/adding? Would following the device tree of a device with similar specs such as the Orange Pi 2 with H3 and the same Wi-Fi Chip be advisable?
shijieteo Posted October 1, 2021 Author Posted October 1, 2021 Just as a follow up, found a device tree from an Ubuntu image from the manufacturer, copied it over to the device and it seems to have gotten rid of the error. Thanks for the help! On 9/20/2021 at 11:36 AM, Werner said: R1 != R1S Both boards may have a different WiFi Chip and therefore the device tree may not fit.
