Because I'm a glutton for punishment, I decided to test a bunch of PCDuino3 images. Hopefully this will be helpful for someone. Feel free to double-check my work.
3.X kernels work perfect.
4.11-4.14 no HDMI Audio
4.19-5.8 there's a bug where the console won't show up if you connect a high resolution screen. It complains about not enough memory reserved for the frame buffer. So if you have a blank screen, it's possibly working, but you just can't see anything. Also, still no HDMI audio even though it's built into the kernel.
5.9-current hangs at "Starting Kernel" showing in the serial port.
Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs).  With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported.  Your report is invalid for one or more of the following reasons (non-exhaustive list):
  • it is for an unsupported board or image (CSC/EOS/WIP/edge)
  • it is for software that is not supported (such as userspace modules installed on top of the core operating system)
  • it has been logged in the wrong forum (for example requests for help that are not actual bug reports)
  • it lacks requested data (armbianmonitor output)
  • it could have been easily solved by a quick search and/or reading documentation
Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat)
