i have buy a tv box mxq pro 4k 5g "8gb ram and 128gb nand".
In a few years i have buy the mxq pro 4k without 5g and i have use the dtb file the meson-gxl-s905w-p281.dtb
Then i have write the armbian image with dd to the sd card.
In the /boot directory i have edit the boot.cmd file with following:
boot.cmd
The most important settings:
setenv prefix "boot/
setenv fdtfile "dtb/amlogic/meson-gxl-s905w-p281.dtb"
Then i have build the boot.scr with this command:
mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
Then i have insert the sd card in the sd card slot from the tv box, push the button in SPDIF for 10 seconds, and then the mxq pro starts, but the linux system didnt start.
Now i would know, why the box didnt start?
Must i use a other dtb file?
I have build the armbian image from source with following:
lepotato
debian bullseye
minimal image without desktop
The kernel i didnt change
Thanks in advance
Edited by andybo
Now i have opened the TV Box.
There ist a kingston Chip 08EMCP08-EL3CV100 inside.
8gb emmc and 8gb DDR3 RAM.
Hm...what armbian Image and dtb File i can use for the TV Box?
Hi thank you for answer.
I have read the Link.
If im home i will download the balbes Image and write it to the SD Card.
How to configure Files stay also in the Link.:thumbup:
Balbes has stopped the work for the TV boxes. Only updates for the os, can use from debian or Ubuntu.
Kernel Updates can only used if everyone Compiled it from the source.
Gives it a link how  explaine  compile the kernel?
Edited by andybo
The Box run now with armbian.
I have write the Multitool Image for rk3229  to SD Card.
The armbian Image i have Copy in the Image folder.
Then i have start the Box with the SD Card inside.
Multitool Starts, then i have done a Backup from the emmc.
After that i have write the armbian image to emmc.
Then shutdown the Box.
Now the Box Starts with armbian:)
The Box have 8gb emmc and 8gb DDR3, but only 1gb DDR3 the system ist knowing.
Whats wrong?
I originally moved this to the amlogic tvbox forum based on the comments in the first post.  However based on the latest comments this appears to be a rockchip based box so moving to the rockchip tvbox forum.
@andybo your box does not have 8Gbyte of ddr3.  The rk 32xx cpus only support a max of 4Gbyte, so there is no manufacturer that would install more memory than could be used.  I suspect what you have thought was 8Gbyte is really 8Gbit which equals the reported 1Gbyte.
@andybo it's wrong that the vendor of the box just faked specs. Your box has a 1GByte of RAM, no less, no more.
