install https://github.com/emmercm/rpi-rtl8812au
error?
$ sudo make
make ARCH=arm CROSS_COMPILE= -C /lib/modules/5.10.60-sunxi/build M=/sr/src/rtl8812au-f1bd10b  modules
make[1]: Entering directory '/usr/lib/modules/5.10.60-sunxi/build'
make[1]: *** No rule to make target 'modules'.  Stop.
make[1]: Leaving directory '/usr/lib/modules/5.10.60-sunxi/build'
make: *** [Makefile:1086: modules] Error 2
Moved to Common issues / peer to peer technical support
Duplicate topic has been deleted since it would have been an invalid issue report anyways and posting the same issue in multiple places is considered abusive behavior.
error?
$ sudo make
The M=/sr/src/... looks wrong to me.  Shouldn't it be M=/usr/src/...  ?
Update: I think that this make has to be done on the system that built the kernel.  This was the case with the old Realtek drivers I built for RPi kernels.  The make needs a valid "build" softlink in the modules directory.  This softlink is only valid where the modules were created.
Cheers,
Steven
Edited by phelum
More details
